  • JPJI
    Spitfire Fan
    • Dec 2018
    • 30
    • Liverpool, UK
    Originally posted by TonyTaff
    Ok now for the hard part applying the decals
    should I clear coat first so that I get a bit of slip
    or paint afterwards. Or do it before and after
    Apply gloss coat first to avoid 'silvering' of the decals. Coat again afterwards to get consistent sheen level of your choice.
    • TonyTaff
      • Oct 2017
      • 39
      Ok so having Coated the plane do I need to wet the decals or are they peel and stick
      i so notice that the small lettering is marked wet transfer
        • 7337
        I'm not sure about the stock markings, but I did use the stock nomenclature and they peeled off after being coated with Minwax Matte finish. The rest of my markings are from Callie Graphics and they work great when applied straight to the surface.
        • TonyTaff
          • Oct 2017
          • 39
          Finally got my spit together. I am sure about Flightline, I think they spoiled the ship for an halfpence of tar ( cheaped out on finish)
          This is my first ever flightline aircraft and probably my last.
          Many Issues including the retracts not working when using a separate receiver Battery.. Turns out retracts have some kind of over voltage detection built in.
          If your run it with the 6s and the supplied ESC they work just fine ( BEC is 5amp at 5volts) My battery would supply 12 amps.. If I add another BEC to drop the receiver battery voltage down to 5 volts retracts work but will not no way no how work with the 7.4 V from a receiver battery... All other servos were fine.
          Also never hook up the led lights without the little blue box they lite very bright for a short period of time.. (nano seconds)
          Finally the decals what a P.I.T.A no instruction as to what the three different types are. and no instructions on how to apply them.
          Slightest touch of a sticky decal on the paint when trying to attach results in paint coming off. Paint is not well adhered to airframe.
          I hope it flies better than it went together.
          • JPJI
            Spitfire Fan
            • Dec 2018
            • 30
            • Liverpool, UK
            As commented on RCGroups:
            Decals are best wet applied so you can slide them around. They should have explained this better in the instructions.
            Over voltage protection on the retracts is better than the magic smoke coming out when too high a voltage is applied to them.
            If you are using a 6+ volt receiver battery, then you should always make sure that all the electronics are rated for high voltage, or use a voltage regulator to reduce voltage to below 6v.
            If you are going to apply a higher voltage to any of the electronics than the manufacturer intended, then they cannot be held responsible for any damage that results.
            Paint is not very well adhered to the foam, which is typical for all foamies. (paint does not stick well to foam)
              Howdy.... The servos and retracts are designed to run on 5.1 volts DC or very close to that voltage threshold. The LEDS are rated at about 2.8-3.0 v dc, and that is why there is a blue box, to regulate that current... You can have 1000 amps available, and that is OK! You just cant have too many volts! I am surprised the retracts didn't fry to be honest.... Good luck with your maiden...
              • RCAV8R
                Certified Plane Nut
                • 355
                • Medford, Oregon
                Originally posted by RichJ53
                Yes you are correct, right rudder is needed and Rob posted this after realizing the error.... I was at the flying field when he was flying the spit that day
                Rich
                Sorry for the confusion guys, Rich and Jerry are correct...I misspoke and the correct rudder correction for torque should be right, not left!
                • RCAV8R
                  Certified Plane Nut
                  • 355
                  • Medford, Oregon
                  I hope you guys will forgive me for a minor hijack, but as a Spitfire enthusiast I hope you find these photos of interest! First, here are some shots of my recently completed 1/32 scale Spit model...lots of experiments in airbrushing, shading, washes, etc., but I love the opportunity to get into the detail! This is a Mark Vb. Rob Click image for larger version
ID:	206960Click image for larger version
Name:	port profile1.JPG
ID:	206961Click image for larger version
ID:	206962Click image for larger version
ID:	206963Click image for larger version
                  • RCAV8R
                    Certified Plane Nut
                    • 355
                    • Medford, Oregon
                    And then I just returned form the Flying Legends air show at Duxford, England. An amazing collection of warbirds, and all flying! About half a dozen Spitfires, some Hispano Buchon M4L's (a Spanish derivative of the ME 109), and on and on! Such an amazing bit of history! Rob Click image for larger version
ID:	206975Click image for larger version
ID:	206976Click image for larger version
ID:	206977Click image for larger version
Name:	spits takeoff.JPG
ID:	206978Click image for larger version
Name:	spit upclose2.JPG
ID:	206979Click image for larger version
                      Beautiful!!!!!!!!!!!!!!!
                      • RichJ53
                        • Nov 2018
                        • 342
                        • Southern Oregon
                        Originally posted by RCAV8R
                        And then I just returned form the Flying Legends air show at Duxford, England. An amazing collection of warbirds, and all flying! About half a dozen Spitfires, some Hispano Buchon M4L's (a Spanish derivative of the ME 109), and on and on! Such an amazing bit of history! Rob Click image for larger version  Name:	spits takeoff.JPG Views:	4 Size:	86.7 KB ID:	206978Click image for larger version  Name:	spit upclose2.JPG Views:	4 Size:	136.1 KB ID:	206979
                        Welcome home sir!
                        Glad you had a nice trip and thanks for sharing your photos
                        we will need to catch up soon.
                        Rich
                        • boomer108
                          Chief Boom
                          • Apr 2014
                          • 867
                          • Chicago IL.
                          Beautiful work RCAV8R!
                          • dblmars
                            RAF Pilot
                            • 14
                            • Pahrump, Nevada
                            Just a suggestion, to all do not bother with any of the stock water slide decals, because Callie grraphics has a fantastic nomenclature decal sheet for under $10.00, and you will save yourself a ton of grief...
                              • 2693
                              Well said, I used her nomenclature on my Spitty, as well as every other plane I have that she has the nomenclature graphics for. They are definitely worth the few extra bucks!
                                • 7337
                                Yep, found that out for myself. I used Callie's decals for all the main markings and made the mistake of using the stock nomenclature decals. The result, hers are still on and the stock ones are falling off. They even ripped while trying to put them on. Should have been my first clue. I didn't use the stock decals on the F7F or the Spitfire, but I used the Blue Angels set on the F8F with success, so I don't know if the decal supplier was changed between the manufacture of the F8F and the Spitfire, but the quality seems to have gone down hill. Anyone have any difficulty with the main markings stock decals??
                                • t01ga
                                  " T "
                                  • 197
                                  • UK
ID:	208196Click image for larger version
ID:	208195Click image for larger version
ID:	208194Click image for larger version
ID:	208193Click image for larger version
ID:	208192Click image for larger version
ID:	208191Click image for larger version
ID:	208190Click image for larger version
ID:	208189Click image for larger version
ID:	208188Click image for larger version
ID:	208187Click image for larger version
ID:	208186 Finally found time to finish off my Spitfire!
                                  Tolga
                                  Instagram: @_t01ga_
                                  YouTube: t01ga
                                    • 4825
                                    TGA, I like it! Lookin' good, Sir. Great attention to detail, too. Best, LB
                                    • t01ga
                                      " T "
                                      • 197
                                      • UK
                                      Thanks LB, much appreciated!
                                      Tolga
                                      Instagram: @_t01ga_
                                      YouTube: t01ga
                                      • boomer108
                                        Chief Boom
                                        • Apr 2014
                                        • 867
                                        • Chicago IL.
                                        Beautiful work T01ga! He looks like he's ready to fly across the channel.
                                        • t01ga
                                          " T "
                                          • 197
                                          • UK
                                          Thanks Boomer.
                                          Tolga
                                          Instagram: @_t01ga_
                                          YouTube: t01ga
