High Speed Buggy (Blue/Green) 1/14 Scale 4WD Buggy - RTR from XK Innovations - WLT-144001
High Speed Buggy (Red/White) 1/14 Scale 4WD Buggy - RTR from XK Innovations - WLT-144001-01
The XK Innovations High Speed Buggy is a 1/14 scale buggy that arrives to your doorstep Ready To Run, full of fun and backed by Motion RC's world-renowned customer service and technical support. This buggy is an absolute blast to drive while achieving speeds a little over 30 mph on pavement. This buggy handles grass, gravel, or even a little bit of snow with ease. Drive on!
Adjustable Suspension Fully independent front and rear suspension work to absorb punishment while keeping your wheels on the ground as much as possible. Adjust the suspension at various points to tune its performance to your preference! |
| Race-Ready Body Style Thrilling performance is matched with an aggressive buggy racer configuration and iconic body style. The shell is quickly removable to access internal electronics |
Easy To Maintain Easy access and user-friendly layout make this buggy very easy to service, repair, and upgrade. Structural and functional sub-assemblies can be disassembled with simple tools. |
| Four Wheel Drive Accelerate with maximum traction using active four wheel drive! |
Durable Metal Parts Unique among many of its peers in this class size, this buggy features several reinforced metal parts in key areas to help withstand the rigors of high speed driving. Key components include steel drive shafts, aluminum shock towers and a full metal underside pan. |
| Upgradeable Perfect out of the box for most drivers, this buggy is also easy to tinker with, upgrade, or customize for creative gearheads looking for an affordable base vehicle. |
Wide Stance Stability A uniquely widened front wheelbase resists rollovers and gives you the advantage while cornering and maneuvering at high speed. |
| Ready To Run (RTR) Everything is included in the box to get you on the road in minutes, just add AA batteries for the radio transmitter! A 2.4Ghz radio transmitter, 2s 7.4v Li-Ion battery, and convenient battery charger are included. |
- Functions: forward, backward, turn left, turn right, direction trimming
- Big wheels and high chassis provide good climbing performance
- Has no problem going through the dirt, grass, and gravel
- 2.4GHz technology with four-wheel-drive system to provide plenty of power
- 4 wheel drive to ensure a stable and smooth driving experience
- XK Innovations High Speed Buggy (Blue/Green) 1/14 Scale 4WD Buggy - RTR
- 2.4GHz Transmitter and charger
- 2s 7.4V 1500mAh Li-Po battery w/ T connector
- Four (4) AA size batteries for the radio transmitter
AGE LEVEL : 14 AND UP
SKILL LEVEL : INTERMEDIATE
BUILD TIME : NONE
| Model Scale | 1/12 |
| Length | 385mm / 16.0in |
| Width | 205mm / 10.0in |
| Height | 145mm / 5.7in |
| Weight (No Battery) | N/A |
| Wheelbase | N/A |
| Ground Clearance | N/A |
| Body | ABS Plastic |
| Chassis | N/A |
| Drivetrain | 4WD |
| Wheel Size (Diameter x Width) | 110mm |
| Wheel Hex Size | N/A |
| Tire Tread | N/A |
| Bushing Material | N/A |
| Suspension | N/A |
| Shock Type | Oil-Filled |
| Transmission | N/A |
| Gear Pitch | N/A |
| Internal Gear Ratio | 6.9:1 / 8.3:1 (select from 2-type) |
| Final Drive Ratio | N/A |
| Pinion | N/A |
| Spur Gear | N/A |
| Differential | N/A |
| Ball Bearings | N/A |
| Brakes | N/A |
| Electronic Speed Control | 45A |
| Motor | Brushed 550 Motor |
| Battery | 2S 7.2V 1500mAh LiPo battery with T connector |
| Max Battery Dimensions (L x W x H) | N/A |
| Servos | 17g |
| Radio | Syncro KT-231P+ transmitter |
| Lights | No |
| Sound | No |
| Water Resistant | Yes |
| Skill Level | Intermediate |
| Assembly Time | 1+ Hours |
| Recommended Environment | Offroad |
.png)
