Official XK Innovations 1/14 Scale High Speed Buggy 4WD Buggy - RTR Thread
  • Official XK Innovations 1/14 Scale High Speed Buggy 4WD Buggy - RTR Thread
    High Speed Buggy (Blue/Green) 1/14 Scale 4WD Buggy - RTR from XK Innovations - WLT-144001
    High Speed Buggy (Red/White) 1/14 Scale 4WD Buggy - RTR from XK Innovations - WLT-144001-01
    The XK Innovations High Speed Buggy is a 1/14 scale buggy that arrives to your doorstep Ready To Run, full of fun and backed by Motion RC's world-renowned customer service and technical support. This buggy is an absolute blast to drive while achieving speeds a little over 30 mph on pavement. This buggy handles grass, gravel, or even a little bit of snow with ease. Drive on!
    Adjustable Suspension
    Fully independent front and rear suspension work to absorb punishment while keeping your wheels on the ground as much as possible. Adjust the suspension at various points to tune its performance to your preference!
    Race-Ready Body Style
    Thrilling performance is matched with an aggressive buggy racer configuration and iconic body style. The shell is quickly removable to access internal electronics
    Easy To Maintain
    Easy access and user-friendly layout make this buggy very easy to service, repair, and upgrade. Structural and functional sub-assemblies can be disassembled with simple tools.
    Four Wheel Drive
    Accelerate with maximum traction using active four wheel drive!
    Durable Metal Parts
    Unique among many of its peers in this class size, this buggy features several reinforced metal parts in key areas to help withstand the rigors of high speed driving. Key components include steel drive shafts, aluminum shock towers and a full metal underside pan.
    Upgradeable
    Perfect out of the box for most drivers, this buggy is also easy to tinker with, upgrade, or customize for creative gearheads looking for an affordable base vehicle.
    Wide Stance Stability
    A uniquely widened front wheelbase resists rollovers and gives you the advantage while cornering and maneuvering at high speed.
    Ready To Run (RTR)
    Everything is included in the box to get you on the road in minutes, just add AA batteries for the radio transmitter! A 2.4Ghz radio transmitter, 2s 7.4v Li-Ion battery, and convenient battery charger are included.
    FEATURES:
    • Functions: forward, backward, turn left, turn right, direction trimming
    • Big wheels and high chassis provide good climbing performance
    • Has no problem going through the dirt, grass, and gravel
    • 2.4GHz technology with four-wheel-drive system to provide plenty of power
    • 4 wheel drive to ensure a stable and smooth driving experience
    INCLUDES:
    • XK Innovations High Speed Buggy (Blue/Green) 1/14 Scale 4WD Buggy - RTR
    • 2.4GHz Transmitter and charger
    • 2s 7.4V 1500mAh Li-Po battery w/ T connector
    REQUIRES:
    • Four (4) AA size batteries for the radio transmitter
    PRODUCT SPECIFICATIONS:
    AGE LEVEL : 14 AND UP
    SKILL LEVEL : INTERMEDIATE
    BUILD TIME : NONE
    Model Scale 1/12
    Length 385mm / 16.0in
    Width 205mm / 10.0in
    Height 145mm / 5.7in
    Weight (No Battery) N/A
    Wheelbase N/A
    Ground Clearance N/A
    Body ABS Plastic
    Chassis N/A
    Drivetrain 4WD
    Wheel Size (Diameter x Width) 110mm
    Wheel Hex Size N/A
    Tire Tread N/A
    Bushing Material N/A
    Suspension N/A
    Shock Type Oil-Filled
    Transmission N/A
    Gear Pitch N/A
    Internal Gear Ratio 6.9:1 / 8.3:1 (select from 2-type)
    Final Drive Ratio N/A
    Pinion N/A
    Spur Gear N/A
    Differential N/A
    Ball Bearings N/A
    Brakes N/A
    Electronic Speed Control 45A
    Motor Brushed 550 Motor
    Battery 2S 7.2V 1500mAh LiPo battery with T connector
    Servos 17g
    Radio Syncro KT-231P+ transmitter
    Lights No
    Sound No
    Water Resistant Yes
    Skill Level Intermediate
    Assembly Time 1+ Hours
    Recommended Environment Offroad
    I just received my XK 1/14 4 wheel drive buggy ,and noticed that the front wheels are splayed out. Is this correct?
