Official Primus MZ24 Mako 1/24 Scale 4WD Car Discussion Thread
  • jbaartz
    • Sep 2020
    • 488
    Version Info: This is a DIY RTR model that comes with pre-built sub-assemblies ready for final assembly. It has everything needed to run, other than 4 AAA alkaline batteries for the transmitter.
    Now available from Motion RC is the innovative Primus MZ24 Mako 1/24 scale on road “DIY” RTR. The DIY aspect consists of components and factory built sub-assemblies that can be quickly and successfully built in less than an hour by modelers of all ages! Don’t let the small size and budget-friendly price fool you; this model features a 2.4 GHz digital proportional pistol-grip transmitter, compact ESC/Receiver with forward and reverse, micro 5g servo, ball bearing-equipped 4WD drivetrain, factory-painted body shell, LiPo battery with convenient USB charger, and more!
    At home on smooth surfaces such as concrete, wood floors, indoor/outdoor carpet or even a pool table, the MZ24 Mako is perfect for father/son race time at home or take it to your local RCP-equipped racetrack for some serious competition. Great for teaching youngsters the basics of RC assembly, the MZ24 will provide its owners many hours of fellowship and fun. Backed by Motion RC’s spare parts support and customer service, this model is ideal for drivers of all ages.
    Comprehensive Package
    The MZ24 Mako arrives with everything you need for final assembly. Simply add four (4) AAA alkaline batteries for the included transmitter and run for fun.
    Conveniently Prefabricated
    All four corners of the MZ24 Mako arrive factory-assembled and ready for final assembly, while the body arrives painted, decorated, and ready for final mounting.
    Powerful LiPo Battery
    An included 3.7V 1S 450mAh battery pack and convenient USB charger deliver thrilling performance and extended run time.
    2.4GHz Technology
    The MZ24 Mako includes a comfortable transmitter that offers adjustable full throttle settings for young or inexperienced drivers, while the integrated ESC/RX delivers fully proportional forward and reverse.
    Capable Suspension
    The MZ24 Mako is fully featured for performance that belies its size. Independent suspension, front and rear gear differentials, full ball bearings, and a shaft-driven 4WD system combine to create a model that is fun to drive and impressive to watch.
    Factory-Decorated Body
    The durable, rigid plastic body of the MZ24 Mako arrives painted, decorated, and ready for mounting to significantly reduce complexity and assembly time.
    • “DIY RTR” means everything included except four AAA alkaline batteries
    • 4WD with independent suspension on all corners
    • Suspension with wheels and tires are factory-assembled and ready for final installation
    • Factory-painted and decorated body arrives ready for use
    • Fun to run on any smooth surface
    • Convenient USB charging
    • All fasteners are the same size—with a precision screwdriver included
    • Primus MZ24 Mako 1/24 Scale 4WD Car - DIY RTR
    • 2.4GHz transmitter
    • 1S 3.7V LiPo battery
    • USB charger
    • Instruction manual
    • Precision assembly screwdriver
    AGE LEVEL : 14 and up
    SKILL LEVEL : Beginner
    BUILD TIME : 30-60 Minutes
    Model Scale 1/24
    Length 145mm / 5.7in
    Width 78mm / 3.0in
    Height 48mm / 1.9in
    Weight (No Battery) 97g / 3.5oz
    Wheelbase 98mm / 3.8in
    Ground Clearance 4mm / .2in
    Body ABS plastic, factory painted and decorated
    Chassis Plastic
    Drivetrain 4WD
    Wheel Size (Diameter x Width) 28 x 12mm
    Wheel Hex Size N/A
    Tire Tread Multi-surface
    Bushing Material N/A
    Suspension Independent
    Shock Type Coil-over springs
    Transmission Direct drive
    Gear Pitch N/A
    Internal Gear Ratio N/A
    Final Drive Ratio N/A
    Pinion 8T
    Spur Gear 29T
    Differential Bevel gear
    Ball Bearings Complete
    Brakes Electronic
    Electronic Speed Control Fwd/Rev
    Motor 180 brushed
    Battery 1S 3.7V LiPo 450mAh (included)
    Max Battery Dimensions (L x W x H) 43mm x 21mm x N/A
    Servos 5g micro
    Radio 2-channel (included)
    Lights No
    Sound No
    Water Resistant No
    Skill Level Beginner
    Assembly Time 30-60 minutes
    Recommended Environment Indoors/Outdoors
