Huina produces some of the most advanced electrically-articulated Hobby-Grade RC Construction vehicles that are Ready To Run (RTR)! This 1580 Excavator V4 is the latest version for 2020, packed with many exciting new features! Weighing 12.5 pounds of almost entirely die-cast zinc alloy metal, this digger features sound, lights, "exhaust effect", 360 degree rotation, metal tracks, hall-effect sensors, and three different accessories. Scoop with the all-metal bucket, grab with the all-metal claw, and bash with the motorized jack-hammer! Durable elevation gears and motorized lead screws are made of steel to withstand the rigors of digging. In fact, this excavator can support its entire weight on only its outer arm! Expand your RC job site with Huina's dump truck, loader, and other RC Construction vehicles.
Ready to Run (RTR) Convenience Zero assembly is required, simply add 4 AA batteries to the radio and charge the included main battery to begin digging! |
| Die-Cast Heavyweight! 12.5lbs of zinc alloy die-cast primary assemblies make this the heaviest excavator in the 1/14 scale market! Its heavy weight provides excellent stability so it can dig more deeply on a wider variety of terrain. |
Upgraded for 2020 This upgraded “Version 4” features all-new hall-effect sensors in the boom, arm, and bucket, negating the need for external limit switches. This system is also controlled by an upgraded MFCB (“Multi-Function Control Board”) with convenient plug-in connections for easier servicing, replacement, and upgrading. |
| Metal Tracks and Independent Drive System Twin 380 Motors power the Independent Direct Drive system, riding on full-metal tracks that power through outdoor terrain on your RC work site. Control both track systems independently for 360 degree turns, pivoting turns, and forward and reverse. |
Powerful and Precise Master the coordinated movements of a real excavator, powered by direct drive motors and steel worm-gear actuators! The Huina C336D Excavator’s steel gears and bearings provide excellent wear resistance to keep you in control. The main boom rotates smoothly on shielded bearings. |
| Detailed and Fully Featured Finely die-cast assemblies and detailed surfaces, functioning LED lights and realistic sounds deliver a satisfying realistic experience as both a desktop display and a functioning RC vehicle. Own the best of both worlds! |
Exhaust Effect The “exhaust effect” further adds to the excavator’s realism, and can be turned on and off directly from the radio controller. |
| Reliable Control Control all functions from the included 2.4ghz radio from up to 100 feet away. All functions are pre-programmed and ready to use. Just add four AA batteries. |
Easy to Service Screw-Together construction simplifies disassembly for custom painting, modifications, or upgrading. As a hobby-grade RC Construction vehicle, all major electronic components use micro-plugs for easy removal. |
| Dependable Operate Huina’s upgraded edition of their most complex RC Construction vehicle with confidence, backed by a full range of spare parts and service from Motion RC! |
- 12.5 pounds, almost entirely die-cast external parts
- Fully independent drive system on metal caterpillar tracks
- 360 degree upper hull rotation
- Steel gear driven boom
- Electric linear actuator driven stick and bucket
- Fully proportional precise control inputs for all movements
- Hall-effect sensors for over limit protection
- Sound system
- "Exhaust Effect" (requires glycerin oil)
- LED lighting
- Detailed cockpit with clear window panels
- Metal bucket, metal claw, and motorized jackhammer accessories included in the box
- Huina C336D Die-Cast 1/14 Scale Excavator - RTR
- 2.4GHz radio transmitter
- 2S 7.4V 1500mAh Li-ion battery with T-connector
- USB charger
- Complete instruction manual
- 4x AA batteries for 2.4GHz radio transmitter
