What's Inside a Typical RTR "Ready To Run" RC Tank
This is a sticky topic.
  • Hellcat 7
    • Aug 2020
    • 115
    • T/S
    Originally posted by karltrek
    I sent them an email. I don’t blame Motion. It’s definitely a Heng Long issue.
    Karltreck, any updates on your issue with this? Learning a lot of stuff; I don't even have a Tank yet lol......Looking to buy the HL Pro-Edition M1A2 when it comes in.
    • karltrek
      karltrek
      • 159
      • Santa Cruz, CA
      Motion was not going to do anything. But that is OK. It's still a metal gearbox. I just told them that they need to tell people that some tanks do not come with "Steel" gearbox.
      • Hellcat 7
        • Aug 2020
        • 115
        • T/S
        Thank you for your reply.
        • SoCalBobS
          • 2754
          • Southern California
          (I'm bored!) Ever wonder what was inside a Heng Long battery case? One of mine died, so I dissected it:
          It's an INR18650 H, 7.4V, 1800mah, 13.32WH pack.
          One could easily pop off the black cases. There'd then be more room for the connector and balance taps in the tank.
            • 5402
            Thanks for doing that but both Toucan and Motion RC have always said it's the same 1800 Lion just in a case...
            • SoCalBobS
              • 2754
              Yes, it had been said before but it's always fun to see for oneself, and share.
              • Vaseline
                • 290
                I take the hard case off them to fit them in the T 90 and others that have a small battery compartment
                I run the HL batteries till they die and to hand out to others when we battle
                • cmdrcody
                  "Grumpy"
                  • Dec 2022
                  • 228
                  • Largo, FL USA
                  Russian T-90 battery options
                  What is the maximum dimension size for a battery to fit into the Russian T-90 tank battery compartment?
                  Can you use both Li-ion and LiPo 2S 7.4V type batteries with the XT 60 connector for powering the tank?
                  Specifically, would the RDQ Series 7.4V 2S 5000mAh 5C TX16S Compatible LiPo Battery - XT60 or the NHX RC 2S 7.6V 5200mAh 150C HV + Graphene Shorty LiPo Battery w/5mm Bullets / XT60 work well in this tank?
                  https://www.racedayquads.com/product...o-battery-xt60
                  https://nitrohobbies.com/nhx9003xt60/​
                  • Quakinking1
                    • Feb 2023
                    • 84
                    How does everyone think of this Rc tank I just purchased as a fist hobby grade “https://www.amazon.com/gp/product/B0...1R527&psc=1”. I have done my research and I plan to arm it with modified metal hinges as armor, swap out the transmitter/receiver, esc, give it some 52t motors, tighten the screws, and grease it up. Does that sound like good preparations for my first hobby grade Rc tank? (I am going to work out the ground tires and remove the rockets)
                    • Rubicon99
                      • 3316
                      Hobby grade? I assume that is said with levity behind it....
                      • Quakinking1
                        • Feb 2023
                        • 84
                        I’m sorry, I’m new to this hobby I should’ve said that I’m converting it from toy grade to hobby grade…
                        • Quakinking1
                          • Feb 2023
                          • 84
                          • ccarley
                            • Jun 2022
                            • 158
                            • Rohnert Park, CA
                            I had purchased that tank (maybe from a different seller) last year. It will be very difficult to bring to the level of the Heng Long Tiger even, in all honesty. It has rubber tracks with rear drive sprockets; those companies seem to use the same lower chassis for different upper hulls to make different tank models. It's a fun toy honestly, but converting it over might be more trouble than it's worth. The motors might be 380 size or smaller, so I don't know how you would get 52T motors in there. The "rockets" are part of the BB hopper assembly, if you don't install those, it won't carry any BBs. It doesn't do IR with it's electronics but if you did convert it to Heng Long electronics it could. It would take a lot of modification really.
                            Now, is that tank fun? You bet! I had purchased that and a couple others for camping last year and it was an awesome idea. They have all been passed on at this point though, as the Heng Long tanks are not that much more money, and are totally worth it for entry into more hobby grade tanks.
                            Here's my daughter driving that Tiger at camp last year:
                            Here's my daughter driving her Heng Long Tiger this year (she got for Christmas):
                            Clay
                            • Quakinking1
                              • Feb 2023
                              • 84
                              It would be much appreciated if an updated tk7.0 post was made. As it’s the current henglong standard. Great post!
                              • Quakinking1
                                • Feb 2023
                                • 84
                                Clay
                                Haha great addition to my inquiry! I never realized you responded. I’m looking into some newer henglong options, I kinda realized it was foolish to invest that much into a cheaper tank.
                                • keilau
                                  • Mar 2021
                                  • 1844
                                  • Windy City
                                  A Heng Long plastic basic version 1:16 RC tank can be had for less than the Supdex RC you purchased. You could have avoid the mistake if you enquired here first.
                                  Nothing wrong if you enjoy playing the Supdex RC vehicle.
                                  • Chris curran
                                    • Aug 2020
                                    • 215
                                    This is great info. I have one question. Where can I fund internal electronics for a 1/6 scale Stuart? The original mother board was ruined by mice.
                                    • tank_me
                                      • Feb 2022
                                      • 1197
                                      Only direct replacement for OEM board would be Ebay as the Stuart has been out of production for over 10 years and the company that made it is also dead (officially in 2012, but effectively in 2009).
                                      • Chris curran
                                        • Aug 2020
                                        • 215
                                        You mean to tell me that I couldn't replace the inner electronics with new variants? With all the guys that build their own, I'm sure there's something I could use.
                                        • tank_me
                                          • Feb 2022
                                          • 1197
                                          Yeah, you can. There are plenty of Stuarts that have custom solutions, but there isn't a drop in solution. Some have used Heng Long controllers running at 12V, but that would require a bunch of rewiring and adding plugs to adapt the Stuart parts to the Heng Long MFU. Any of the aftermarket boards like Clark, IBU, TCB, Elmod, etc can all be adapted to run the Stuart. Once again, all of those would require rewiring of most of the tank. The Stuart uses an integrated receiver that is built into the main board. It's basically like a Heng Long controller since it does all the sound and action functions. Everything else in the tank is pretty standard stuff like brushed motors.
