IR Battle Systems?...... Heng Long 6.0 vs Tamiya
  • #61
    That's a great picture of something I did not get. My wiring harness is completely different. You send me your email address and I'll send you a photo. that's they only way I know how to do that.WFraden1@aol.com
    • #62
      Posting a photo here is easier than emailing. At the bottom, below the smilies click on "Upload Attachments". A box will pop up so you can browse to where you have your photo. After selecting the image it will automatically upload. When it's uploaded you'll see it below. Just select "medium" and hit the post reply button.
      • #63
        William Fraden OK, got your email and here is your photo..
        Click image for larger version  Name:	20200601_164712_HDR_resized.jpg Views:	0 Size:	170.2 KB ID:	258014
        Looks like you have a 5 pin 5 wire harness AND a 2 pin 2 wire harness. Is this correct?
        • #64
          thanks now do you see what Ive been saying. not the same
          • #65
            I'll have to defer to Rubicon99 as I don't know what the turret plug looks like for the T-34.
            • #66
              its a 3 plug. I was told I would have to make a hole for a 5 wire plug.
              • #67
                Ok it’s simple. Yes you have six wires. Just remove one of the outer wires on the four wire harness and discard it. Now you will have a three wire harness and a two wire harness.
                You will still need to remove the HL 3 pin connector and enlarge the whole to fit all five wires and secure them to form a mount that the IR receiver plugs into.
                Just make sure the positive, ground and signal wires are in the correct location on both the IR receiver and in the MFU slots. Take a photo of them prior to unplugging from the MFU. This will help ensure you know which one goes where.
                **HL uses red for power, white for signal and black for ground.
                • #68
                  new picture of the 5 wire and 2 wire
                  • #69
                    Rubicon99 Here is a new picture William sent. He does have a 5wire and a 2 wire.
                    Click image for larger version  Name:	5wire_resized.jpg Views:	0 Size:	97.5 KB ID:	258045
                    • #70
                      Ok use the five wire harness and discarded the two wire harness. Three wires to the IR and two for the LEDs.= five wires.
                      • #71
                        So the black and white would be the black and red on the picture on the other page.
                        • #72
                          I changed the colors of the wires in this image to reflect the wire harness you have..
                          • #73
                            • #74
                              thank you
                              • #75
                                For clarification, The two wire is because you also ordered a 4 pack of emitters. The 5 Wire is for the receiver. The diagram is also on the product page itself.
                                • #76
                                  are there any plans to 3d printers out there to make the shades?
                                  • #77
                                    Shades for which IR receiver, HL or LegoDEI?
                                    • #78
                                      HL got somene here that has a 3d printer
                                      • #79
                                        The STLs can be found in this thread, Alphas second post at the bottom. https://www.hobbysquawk.com/forum/rc...mored-vehicles
                                        • #80
                                          Just curious about the stock HL battle system 6.0. Just getting back into this hobby after 10 plus years. Back then we all had Tamiya Tanks with a few hand built tanks. All with Tamiya systems. I just got my second HL tank to I can practice ( T34 and Panther both pro models). Tried them out in the house in semi dark room and dark room. Well it's nothing close to what I remember with my Tamiya tanks. we could hit each other across the back yard. The HL system it's 2-3 ft and that's it. Lucky I have the Lego system coming for the second tank (panther). When it shows up both tanks will get the same system with the HO emitters. If these shot like the video it will be great and I can start to promote these things again. Presently working on a tunnel and looking for old doll houses for a town.
