iR Biatholon or Flag Capture Targets
  • Jdcrow
    • Mar 2019
    • 193
    • Bentonville AR
    I ran across Stanlley's RCTankLegion YouTube Page. Great stuff.
    Alpha - we definitely need a source (Hint Hint to Heng Long Factory) for generally available ir Targets. Especially since he created these using HL parts and 5 targets can operate off one transmitter.
  • RichJohnson
    • 1276
    We have been buying IR targets from a site called RCtankhobby if i recall it correctly. Rubicon99 and I have some. I used them for the IR part of our RC Tank Trials event that was set up similar to a model boat regatta but with tanks. He only makes them if buy a bulk lot of 10 so i had the split an order.
    One guy in LA Tank has converted some iR targets into huge boxes with a flashing beacon and boom sound when it gets hit.
    tamiya makes land mines for their 1:35 IR mini tanks but they do not work with 1:16 for some reason. Targets and mines would be awesome to be commercially produced but they would need to be compatible with the tamiya standard the hobby uses and, be a bit better compatible than the current HL 6.0 is right now. But, this does open a door for a whole new world of play if they were produced.
    • Jdcrow
      • Mar 2019
      • 193
      • Bentonville AR
      Nice.
      We are starting with a small armory. Just 3 of us. So this would definitely add to the activity. Plus the iR target games should keep the projectile police from becoming Moriarty's with all their negative waves. Woof Woof!!!
      • Hellcat 7
        • Aug 2020
        • 115
        • T/S
        Originally posted by Jdcrow
        Nice.
        $7 Modular IR Target
        Oct 15, 2020, 04:15 PM
        Modular, readily available IR target that I cooked up. It is compatible across all board types, including but not limited to Tamiya, Taigen, IBU, OpenPanzer, and HengLong. Can be powered through any battery that is 3V - 5.5V.
        This allows a wide range of batteries to be used, including but not limited to: 1S (3.7V) LiPo, 1S 18650 Li-ion, CR2032/2016 coin cell, 3AA, 3NiMH.
        Depending on your application and size needed, you can choose the battery pack and capacity to fit.
        Available now at https://www.etsy.com/shop/LegoDEI.
        • Hellcat 7
          • Aug 2020
          • 115
          • T/S
          I've seen Stanley's videos also and what a robust program he has. I too will be mirroring his ideas. I am in the process of starting a local club here in Olympia.
          • DevilDog77
            • Dec 2020
            • 27
            I’m done here in the Vancouver WA area. Please keep me posted on your club as I would be willing to come up for the day when you have events
            • Hellcat 7
              • Aug 2020
              • 115
              • T/S
              Roger, sure will. I'm also with NORDPAC check out site at (https://groups.io/g/nordpac).
