I got mine, a King Tiger, Pro version for my FIRST RC tank. Lord love a duck, the wife will be....angry...?? LOL
When will the henglong tanks at Motion Rc be available for purchace?
Hi alpha I have question when will the Panther G be back in stock, it says it is out of stock already. It cant be gone now cant it because I want it available in mid to late May 2020Comment
Leopard and Abrams on the way! Shermans and Challenger soon to follow! Oh and the King Tiger too!
BobComment
Hi guys, my first tanks arrived today. Both Pro models, King Tiger and a Tiger 1. I will be swapping over to XT60 connectors and using some 2200mah packs.
Alpha, how easy to waterproof the hull? I just want to be able to go through a bit of water without it getting into the lower hull. I don’t care if it gets in the battery compartment. I was going to put some silicone where the battery wires come through, but are there any other spots I should look into?
Water will get in no mater what you do within reason to try and seal the tank. The main water intrusion points are the on/off switch and the drive axles. The holes the axles go through can be sealed with the bearing upgrades or you can use grease around the shaft and axles. That is messy though.Hi guys, my first tanks arrived today. Both Pro models, King Tiger and a Tiger 1. I will be swapping over to XT60 connectors and using some 2200mah packs.
Water inside will not really effect the motors per say but will short out the MFU/control board.
A rule of thumb many of us that have been tanking for a while use is to not run the tanks through water or if you just must for the fun of it, then water no higher then the placement of the MFU/control boards position in the tank. A quick splash through a small puddle usually won’t hurt anything but wading through water of 3-4 inches deep is.Comment
Don’t expect a shipment in Feb. That is the start of Chinese New Year and NOTHING moves out of China until it is over. So at best IF there is a shipment, then early April at the earliest is my guess.If Feb 2021 is the next shipment, I will surely put in an order for a HL T-34 85.
I hope the incoming shipment from China is not part of this load that was lost on the news couple days ago..
. Got a Sherman tank coming
