FPV for my m1a2
  • Sappo
    • Feb 2020
    • 346
    FPV for my m1a2
    Just wondering what would be a good fpv camera to put in the turret of the m1a2?
  • NCflying
    • Feb 2020
    • 18
    Any small AIO setup should work.
    • SoCalBobS
      • 2717
      • Southern California
      Looking for a generic FPV thread, or maybe I could ask a question here.
      I have a combo camera/transmitter that works off 3.5 to 5v, basically from a receiver circuit. Is there a takeoff for this voltage on the MCB? This’ll be for a new M1Abrams. Any answer is welcome!
      • Rubicon99
        • 3311
        You can tap power from a number of slots on the 6.0/1 MFUs so you should have no problems. The easiest location that is unused is the “aiming” light slot. If you need more then 3.5v you can use the aux fan or one of the smoke system slots.
        • SoCalBobS
          • 2717
          Rubicon, thanks. Was it you who installed a camera in the CITV post? If so, did you post an install thread, like where the VTX was placed, etc.? If not, might you know who/where? Thanks!
          • Rubicon99
            • 3311
            It was not me. I believe it was forum member Alpha that did the Install.
            • JIMSIX
              • 3
              where can i find voltage output's off the main board for a fpv i need 7 volt's min
              • Rubicon99
                • 3311
                For that much voltage you will need at least a 6.0S MFU and might be able to take it from the smoke unit heater. Though it might be safer to directly take from your power/batter lead lines.
                • Arcright
                  • Mar 2020
                  • 16
                  If you use a Lipo in your tank tap off the balance lead but just pick the voltage for one cell. This also helps with interference and you can also put a capacitor somewhere across the feed to the VTX to reduce voltage spikes. I only ever use power straight from the main pack or a separate tiny lipo as using BEC’s and like puts noise in the system?
                  • SoCalBobS
                    • 2717
                    Also contemplating FPV on an Abrams, Challenger or Leopard. What is the access to the turret like, particularly the bustle? i thought I'd add stuff to my T-72, but with such a small turret, there's virtually no room to run wires, etc.
                    • Rubicon99
                      • 3311
                      The turret on those tanks are HUGE inside. Nothing like the T72.
                      • SoCalBobS
                        • 2717
                        R, thanks. Looking at the T-72, it's beautiful, but might not be the best rough terrain player - barrel length, external stores and such. An Abrams could house the Lego IR setup and FPV much easier. Besides, the T-72 needs an adversary!
                        • Rubicon99
                          • 3311
                          The T72 even with stock 380 motors and stock plastic or metal tracks is an excellent all around tank off road, but due to its low ground clearance does have limitations. I will be soon be posting an updated review about the T72/90 similar to one I wrote a few year back on another forum. If you have seen my recent Instagram short videos some of those were taken durning the updated review testing. Instagram @ fsttanks
                          The Abrams has a lot of internal space that lends itself to easier modifications. It also lends itself to an easy “long travel” suspension modification that can hugely improves its rough terrain performance and overall smoothness of driving. Couple this with some 390 red motors, drive shaft support bearings and set of Tamiya (Abrams or Leopard 2) tracks and you will have an almost unstoppable off road monster of a tank. I will be writing about this modification IF I can get my hands on one of the new 6.0 Abrams form Motion RC soon.
                          Oh and YES it also does makes a great opponent for the T72....
                          • Sappo
                            • Feb 2020
                            • 346
                            I would love to see the long travel suspension mod you have done. Would it be possible to retrofit it to the t90 as well as the m1a2?
                            • Rubicon99
                              • 3311
                              The two suspensions are a little different and require a different approach to the modification. Chiefly among the difference the T90 (T72) has much shorter arms and larger road wheels that are closer together. This limits the range of movement that can be achieved. My extensive testing showed the T90 (T72) suspension mod is not really worth the effort and time it takes to do it.
                              The best way IMO to achieve better off road performance for the T90 & T72 is by upgrading the tracks to a set of Mato or DKLM RC dual pin metal tracks. These have more aggressive track profiles and are more flexible. The flexibility let’s the suspension work more effectively and the aggressive profile doubles the grip over stock metal HL tracks on all surfaces.
                              Sorry for “thread jacking”. If folks would like to know more we should start another thread so this thread can get back on topic.
                              • SoCalBobS
                                • 2717
                                Hi Alpha. (little plane humor there) Was it you who mounted your fpv camera in the Abrams CITV? If you ran a thread on it could you direct me there? If not, I do have some questions if you're willing to share.
                                What camera? I've seen a number of 6mm square tiny cams on eBay. Was it one of these?
                                What VTX? And where did you mount it and the antenna?
                                What power source did you use? Tapped off the main battery, or?
                                My goal is to have a FPV and Legodei IR receiver in an M1 setup, for battling and showing off!
                                Thanks in advance.
                                • Arcright
                                  • Mar 2020
                                  • 16
                                  Just in case anyone is thinking of going FPV here's a couple of videos. First one is with the mic's inside the turret and video taken from goggle DVR.
                                  2nd is with the mic's taped to the outside of the turret
                                  3rd is direct from the Runcam2 SD card, I can't show you the FPV feed from the R2 as both my VTX harnesses are in use on my two FPV trucks.
                                  • Arcright
                                    • Mar 2020
                                    • 16
                                    Drawback of the Runcam2 is the size and colour, good news is there is a new 4k version out ?
                                    • JIMSIX
                                      • 3
                                      Thanks now i got the volt's i need when i have this FPV up i'll show yal the set up i think you'll get a kick out of it , look out grand kid's hear comes grumpa
