Built a IR Target
  • Rudinater
    • Mar 2020
    • 76
    • Houston TX/Bend Or
    Built a IR Target
    I Finished up my IR Target Project. This one is just has flashing LED's when it's hit, but there is no reason you couldn't add a smoke system or a motor to raise a flag. I built the circuit board, used a hang long apple with a sun shield I 3D printed. Power is 3 AA battery's. Put it on the ground or in the back of a RC truck and have some target practice. :-)
    https://photos.app.goo.gl/MP4NcyrwUB63d3629 Video of it in action.
    Click image for larger version  Name:	Target.jpg Views:	0 Size:	205.7 KB ID:	261651
Name:	IR detection and Flasher Circuit.png
  • Beeg
    • 1335
    • Texas
    Sounds like a cool unit. Unfortunately none of the image links work. The google video link works but won't play on my machine for some reason. Probably don't have a modern enough OS...
    • Rudinater
      • Mar 2020
      • 76
      please retry now.
      • Rudinater
        • Mar 2020
        • 76
        Testing
        • Beeg
          • 1335
          • Texas
          Yeah! Everything shows up now. Thanks!
          • Sureshot
            • 235
            Are you considering making them for sale for those of us electronically challenged?
            • Rudinater
              • Mar 2020
              • 76
              Nope just a part of my hobby. Here is a link to one that some one is selling. They just showed up in the last month or so. https://www.etsy.com/.../ir-pillbox-target-38khz-signal... A member of our local club bought one. It works as well.
              • Sureshot
                • 235
                Thanks for the link.
                Think I'll order one of those. Should work great for gunnery practice at home.
                Steve
                • quitcherbitchen
                  • 923
                  • Altadena, CA
                  Thanks for posting. I have made air cannons that make fake explosions tied to my transmitter using a standard receiver, but no accuracy was required. This might just be the ticket for the trigger.. any parts list you can share?
                  • Rudinater
                    • Mar 2020
                    • 76
                    All the parts are listed on the diagram above. The IR Receiver unit is the HL 6.0 apple and costs about $3. The IC chip is a IC 555 timer chip. LEDs are 5mm 2 - 2.2 volt LED's Power is 3 AA battery's in a holder.
                    • quitcherbitchen
                      • 923
                      • Altadena, CA
                      Thank you and again thanks for sharing.
                      • Rudinater
                        • Mar 2020
                        • 76
                        If you have any questions let me know. :-)
                        • mheli
                          • Jul 2022
                          • Kinnelon, New Jersey
                          I know Im a little late to this . But will it work with a Heng long 7.0 system?
                          • Rudinater
                            • Mar 2020
                            • 76
                            Yes, the HL 7.0 system is also Tamiya compliant so they should all play well with each other.
                            • Vaseline
                              • 290
                              Rudinater: What is the # on the transistors you used for your IR target
                              Thanks
                              • Rudinater
                                • Mar 2020
                                • 76
                                Thanks
                                Both Q1 and Q2 are general PNP transistors such as 2N3906,2N2907, BC558
                                • Vaseline
                                  • 290
                                  Thank you sir
                                  • 761st
                                    • May 2022
                                    • 392
                                    Very cool! I want one in my diorama.
