Transport cases
  • Transport cases
    Surprised that there isn't a topic about this. So what do you guys use to transport your tanks?
    When I was looking for a good tank transport case I couldn't really find anything suitable ready made. At least not in the Netherlands or in Europe. So I resorted to this:
    I bought a big aluminium trunk of the brand "Defender" and clad the sides and bottom with 5mm thick EVA foam. After that I used sheets of 3cm EPE foam to make a tray for the tank and a smaller tray for the remote control and two battery packs.
    ​​​​The trays are removable, so can be swapped if I would ever feel the need.
    Now all that remains is to take it into the wild. :)
ID:	268221Click image for larger version
    A few of us here in the States use plastic tool boxes like this "Stanley Fat Max" box. Click image for larger version
      I hadn't even thought of cases. I just put mine in my truck with my planes. But, these are great ideas.
        HDMM I actually looked at the Stanley Fatmax before opting for an aluminium case. But for my King Tiger I think it would've been a bit too small.
          Prowler901 ​I like making stuff, so this was a fun little project. I probably won't be transporting the tank a lot as I don't own a car (hey it's the Netherlands, we take trains or bike everywhere ​​​​​​). But at the least it's nice to have a sturdy dustfree case to put it in for storage.
            I did that too, but the heavier tanks will actually roll, had my King Tiger roll and bump into something else going around a corner, luckily nothing was broken.
              Definitely one of the harder tanks to transport 😎
                My tank hauler is the Home Depot 26" tool box for 22.00. both my tanks fit into there one box (T34 and German Panther).
                  William Fraden I can see that working very well with the smaller tanks.
                    A couple of months ago I found this box at Goodwill (thrift store) for $25!
                    I guess it's an equipment carry case for musical equipment or some such. Way too good of a deal to leave behind.
                    I immediately set to work on modifications and decorating.😉 Click image for larger version
ID:	270540Click image for larger version
                    I first built in a removable shelf so the case can accommodate two tanks.
ID:	270549Click image for larger version
ID:	270548Click image for larger version
ID:	270547Click image for larger version
                    Then I went about the tedious task of stencil making and masking.😒
ID:	270542Click image for larger version
ID:	270543Click image for larger version
                    Once I was happy with the masking job, out to the great outdoors for paint! Click image for larger version
ID:	270551Click image for larger version
ID:	270550Click image for larger version
                    So this is my first carry case project and I have a few more planed. It was actually quite a bit of fun!😃
                    This is the end results.
                    Trying my hand at stenciling a logo.(winged hammer, Manowar)Looks pretty good (to me) so far!This was a fun project and not particularly difficult to do. (so...
                    • #11
                      That came out really sharp, Pynaegan ! Did you seal it with a clearcoat?
                      • #12
                        Pynaegan That looks real slick, and a great find! I like the idea of adding layers for multiple tanks. Think I'll do that as well with my xase once I get a second tank. :)
                        • #13
                          Thank you! I thought about a clear coat for about ten seconds and decided against it. (my last clear coat job was an utter failure)😆😒
                          The surface of the box is deceptively textured and porous so it took a number of passes to get the "black" to disappear. I was afraid my lack of skills would leave my paintwork dull and being a porous surface would be next to impossible to start again. (If'n it ain't broke, don't be a fix'n it)😏
                          HOLY SMOKES!
                          I just looked up the box I have for the first time!😲
                          Looks like it's worth about three to five hundred dollars! (well...before I "had my way" with it)😆
                          If I had to make ANY recommendations, it would be "Frogtape".
                          https://www.amazon.com/Duck-1396748-...45142158&psc=1
                          The green tape on my project was frogtape.(no bleeding)😃
                          The blue tape on my box was regular masking tape. (occasional bleeding)😒
                          Next time will be Frogtape all the way.😏
                          I'm sorry I didn't document the entire modification as I should have. Once I start picking up tools, I get into a "groove" and forget to take pictures.
                          • #14
                            Thank you!
                            When I get a moment, I'll try to make some footage of how I mounted brackets in the case and made the shelf as well as the packing. I can pack both tanks along with all the accessories and even invert the case without damage to any of the contents.
                            (at least thus far)😆
                            I'll try to get that done by this weekend.
                            • #15
                              Pynaegan Thanks, that would be very insightful!
                              • #16
                                Sorry it took so long to follow up. (life and such)
                                After measuring for the height of the shelf, I pop riveted some two inch brackets to the inside.
ID:	274815Click image for larger version
ID:	274809Click image for larger version
                                Made the shelf to fit the Tiger 1
ID:	274812Click image for larger version
ID:	274817Click image for larger version
                                Cushions for the Tiger 1
ID:	274810Click image for larger version
                                A bit of spacer padding to keep the King Tiger in place.
ID:	274814Click image for larger version
                                Padding for the Tiger 1 and it's controller.
                                Cavity at the end of the chest holds batteries, charger and FPV goggles.
ID:	274819Click image for larger version
                                Clamp down the lid and we're ready to travel!
                                • #17
                                  No worries mate, glad you posted those pictures! It looks very ingenious. In wonder if I can do something similar with my case.
                                  • #18
                                    I've run across a couple transport cases that are purpose built for 1/16 scale tanks, a little pricey though.
                                    matomart,Matomart.com,rc,toys,RC Tanks,RC Helicopters,RC Planes,RC Boats,RC Trucks,Cool RC Toys,RC Tank Accessories,Other Accessories
                                    Best regards,
                                    Cris B.
                                    AMA#L945841, NASA#2845, JPO#2503,
                                    NSRCA#4603, IMAC#7357
                                    • #19
                                      Those look nice, but they're nigh impossible to find here in Europe. The price though I think is very reasonable. My custom case was actually more expensive all totaled up.
