Restoring an old Tamiya Leopard A4
  • Meter Rat
    • 506
    • Argyll and Bute, Scotland
    Originally posted by Panzermechaniker
    I have always thought the early Leopard was a great looking tank. Looking forward to seeing all rebuilt. I'm enjoying tearing my own tanks down and rebuilding them a lot these days
    You do a great job of rebuilding, and repairing them.
    Short post. As I am waiting on parts for the chassis of the Tamiya Leopard 1A4, a small amount of work was done on the body. Removal of the plastic mudguards, and the fitment of new rubber ones. Will need to order some 1mm Meng bolt heads to finish this area.
    Bit of scratch work made some tow cable holders, and the spaced off the the tool boxes as per the prototype.
    Dry build up of the chassis which highlighted some issues, and a few mistakes, of my own making. These will addressed
    • Meter Rat
      • 506
      After some absence. Work has continued on my Leopard 1A5DK, to the point where some paint could be applied. Tools on the rear deck have been replaced. Lots of filler and sanding required now. Click image for larger version
ID:	431641 Click image for larger version
ID:	431642 Click image for larger version
ID:	431643 Click image for larger version
ID:	431644 Click image for larger version
ID:	431645 Click image for larger version
      • SoCalBobS
        • 2754
        • Southern California
        Wow! Great job on a great tank.
        • MrChef
          • Jan 2023
          • 510
          • New York, Not the city
          WoW! You've done some great work here Ian! The white paint brings it all together. Nice work sir!
          • Meter Rat
            • 506
            Made a right stooshie of the paint. The top coat reacted with the original paint, or some contamination.
            Before.
ID:	431725 Click image for larger version
            After two hours of sanding, and sore fingers.
            Still need to spend more time sanding, with ever finer wet and dry.
            • RichJohnson
              • 1276
              Yikes that paint reaction sucks. That can just ruin a great model. Love your work on the DK A5 upgrade,
              live finshed two so far, My BE1 and a fictitious 1a7 upgrade which was my mechanical prototype for upgrading uperations in the models.
              My AS1 is half done, I haven’t decided in the camo pattern yet but it will be a version of mudcam not Auscam.
              I also have a C2 mexas sort of half done, working up the 3d printed armor is a real pia.
              Good luck with the paint solution. I hope your able to smooth it out and repaint it to be a good coat for such a nice build.
              • SoCalBobS
                • 2754
                I had something similar happen once. I used Testor's paint and decal remover to get down to the bare plastic. I don't know if it would work on your project. There also a lot of "old wive's tales" chemicals that strip paint without affecting the plastic. One I did use was carburetor cleaner, but I can't remember the brand. Good luck however you proceed.
                • Meter Rat
                  • 506
                  Cleaned up the mess. Went old school, with emery paper, then wet and dry used wet. Two hours of my life I will never get back. At least I was able to do it in cooncil time. And use their heating to dry it. Click image for larger version
                  • Meter Rat
                    • 506
                    After stripping the paint off, and a thorough clean, new paint was applied.Stencils were used for the UN markings. I need to paint the bridge weight marking on the front lower hull, then weathering can continue. The lights were wired to give headlights and taillights, and separate switched convoy marker lights. Weathering, is going to be enjoyable, as these got filthy due to the kosovan weather.
ID:	432806 Click image for larger version
ID:	432805 Click image for larger version
ID:	432804 Click image for larger version
ID:	432803 Click image for larger version
ID:	432802 Click image for larger version
ID:	432801 Click image for larger version
                    • RichJohnson
                      • 1276
                      Nice work. Cool, detail on the lighting.
                      Another leopard 1 comes back to life.
                      • tank_me
                        • Feb 2022
                        • 1197
                        Cool build. I spent about 3 months in Bosnia back in 1996.
                        • Meter Rat
                          • 506
                          Managed to complete most of the weathering on my Leopard 1A5DK. A few bits have come off in the construction, and will need remaking. Now just waiting on some matte finish to seal in the weathering. Looks like one of the smoke dischargers needs back in place.
                          I can not believe that I started on this just over 5 years ago.
                          Click image for larger version  Name:	IMG_6368.jpg Views:	0 Size:	95.1 KB ID:	433122 Click image for larger version  Name:	IMG_6370.jpg Views:	0 Size:	78.7 KB ID:	433124 Click image for larger version  Name:	IMG_6371.jpg Views:	0 Size:	69.6 KB ID:	433125 Click image for larger version  Name:	IMG_6369.jpg Views:	0 Size:	80.6 KB ID:	433123 Click image for larger version  Name:	IMG_6362.jpg Views:	0 Size:	124.1 KB ID:	433126
                          • RichJohnson
                            • 1276
                            Pretty nice. I drove both of my finished ones around this weekend in our San Diego battle.
                            each one is set up slightly different and I’m not quite satisfied with either one as far as driving and battling and loosing speed during the hit knock out process.
                            my Belgian BE 1 has taigen trannys (39:1 ratio) with 380 motors using a Tamiya dmd11 and uses 8.4 volt battery and 3d printed plastic Tamiya tracks and it’s slow. Then as it gets hit it gets even slower until it just can’t move, I had 390 motors in it but was drastically overpowered and put too much torque on the ground and would whip around nearly uncontrollably in turning.
                            My modernized 1a7 with all the fake armor I added, has Henglong red ultimate II tranys (33:1 gear ratio) with 390 motors and uses a 7.2 volt battery and the metal rubber pad track and is quite a bit faster. It is just slightly squirrelly when driving but performs better when dashing across an open field, and as it takes the 6 hits and slows down on each one.
                            Im still not quite satisfied with either but I like the performance from the 1a7 better.
                            I still have several more tanks to build yet and am trying to work through what is the best way to set them up.
                            The dmd11 has a very different driving algorithm in it designed for the centurian kit and trying to get a good trany design to match it is challenging for a good smooth logarithmic curve while driving.
                            • Meter Rat
                              • 506
                              The niece visited, with the child who is the spawn of satan, and simply does not understand the word no. As it could not get his own way, he pulled the shelf off the wall with the Leopard on it. Damaged the transporter it was on, and wrecking the Leopard.
                              Damaged transporter cab.
ID:	442099 Click image for larger version
                              Broken search light and gun.
                              Barrel broken in three places.
ID:	442102 Click image for larger version
                              Gear box output shaft broken.
                              • cleong
                                • Feb 2024
                                • 34
                                Visitation rights have, understandably and rightfully, been firmly revoked.
                                • RichJohnson
                                  • 1276
                                  Wow. So sorry to see this. I can imagine how the succeeding events transpired. How old is the child?
                                  • Meter Rat
                                    • 506
                                    I say nothing, on the matter. Because I will be the one whom is wrong. Oh well! **** ‘appens. We will be diswayding future visits, as this is not the first time he has wrecked objects when he been unable to get his own way.
                                    • Meter Rat
                                      • 506
                                      Thank you.
                                      I say nothing, on grounds of incriminating my self. The child is seven. Even our neighbours boy, who is the same age, and frequently asks to use my models, and has gained the skills to use them with care, and respect. Just turned and told him he would be in trouble
                                      Oh well, it can be repaired.
                                      • RichJohnson
                                        • 1276
                                        Unfortunately so many parents today do not teach their kids NO and are raising brats. My son is 11 and is quite respectful most of the time.
                                        I once experienced a couple young teens maybe 10 and 13 who were invited into our tank battle area with their grandmother. The older one was caught grabbing the barrel of my 3d DKlM M60a3 while it was on my table, it’s a very expensive custom Tamiya grade model I built before Tongde existed. When I returned home I found everything inside the turret broken apart. I wept greatly and sat it on the shelf and retired the model.
                                        The same child suckered my son into letting him drive his Tamiya Pershing when I was not aware and he proceeded to ram it into a concrete wall over and over until he broke the whole barrel and mantlet off. My son is a generous and kind kid and shares his toys freely but we had to have a talk about limits and strangers and it’s ok to say no especially on special expensive toys.
                                        • Chris curran
                                          • Aug 2020
                                          • 215
                                          This is sad to see the destruction of such a fine model. It can be fixed. It will be fixed.
