Restoring an old Tamiya Leopard A4
  • Meter Rat
    • 504
    • Argyll and Bute, Scotland
    Repairs got underway with my Leopard 1A5DK. The gearbox output shaft was drilled out 2.5mm, then tapped out 3mm. A 3mm threaded bar was stewed in, and fixed with JB Weld. When this had dried, the second part was screwed on and again fixed with JB Weld. No photos as I forgot.
    Today, as it is summer in Scotland, and the rain is coming sideways , some more repairs were carried out. Scratch built a new reversing wand. ​​​​​​
    Then new fixings were installed for the mantlet cover. This will have fine elastic threaded through it.
    While this was all drying a start was made on scratch building a new mount for the EMES18. I’m now waiting on it all drying, so it can be carefully trimmed down, and the EMES fitted.
ID:	449624 Click image for larger version
ID:	449625 Click image for larger version
ID:	449626 Click image for larger version
    It looks rough in the pictures.
    • SoCalBobS
      • 2717
      • Southern California
      I like the rough texture. You do so well, perhaps you should have your nephew knock a couple more tanks off the shelf!
      • RichJohnson
        • 1276
        I like your mount, coming along nicely. I finally built my spotlight bracket last month and mounted it. I used brass and made it actually screw on and off,
        .. ugh crazy needless work.
        • Meter Rat
          • 504
          Final job on this repair was to the gearbox. If anyone has read the drivel I write, then due to the offspring of spawn, the gearbox out drive was damaged.
          Rather than use a new pair of gearbox, which are book marked for a second Leopard 1 restoration, I would attempt to repair them., with a bit of old school engineering.
          First job was to drill and tap both parts of the drive shafts.
          Click image for larger version  Name:	IMG_1300.jpg Views:	0 Size:	68.7 KB ID:	449973
          A screw was installed, and both parts fitted together.
          Click image for larger version  Name:	IMG_1301.jpg Views:	0 Size:	123.9 KB ID:	449974 Click image for larger version  Name:	IMG_1302.jpg Views:	0 Size:	63.6 KB ID:	449975
          This was all aligned, and crossed drilled, and small pin fitted.
          Click image for larger version  Name:	IMG_1303.jpg Views:	0 Size:	109.6 KB ID:	449976
          These pins were held in with a small amount of JB Weld.
          Click image for larger version  Name:	IMG_1304.jpg Views:	0 Size:	49.1 KB ID:	449977
          Unfortunately, I pined it to well, and the screw broke, on the first drive.
          Click image for larger version  Name:	IMG_1305.jpg Views:	0 Size:	100.1 KB ID:	449978
          I admitted defeat, and installed the pair of new gearbox.
          Click image for larger version  Name:	IMG_1307.jpg Views:	0 Size:	108.9 KB ID:	449979
          While seeking solace at the bottom of a pint pot some further ideas, came to mind, so I have not given up yet on the repair of these gearboxes.
          • SoCalBobS
            • 2717
            Record the cost, and when the spawn reaches adulthood, present him with the bill...with interest. Include labor.
