Heng Long gearboxes
  • Sureshot
    • 235
    Heng Long gearboxes
    I have a Tiger 1 with a plastic gearbox.
    I upgraded the tracks recently to metal with metal sprockets and idlers and the extra weight and traction sometimes causes the clutches in the gearboxes to slip.
    I would like to buy a steel gearbox to replace the plastic one.
    Looking on Motion's website I see several gearboxes in stock of different configurations but no clue as to which tanks they fit.
    Can anyone here tell me which one fits a Tiger 1?
    Thanks,
    ​​​​​​​Steve
  • Beeg
    • 1335
    • Texas
    Tiger I should be ML49 gearbox and you can use Red or Black/Blue motors.
    Click image for larger version  Name:	HLTank_GearboxMotors.jpg Views:	0 Size:	234.4 KB ID:	272855
    • Sureshot
      • 235
      That's a good reference chart but for some reason Motion doesn't reference part numbers just descriptions like high/low short shaft etc.
      Thanks,
      Steve
      • Beeg
        • 1335
        • Texas
        I guess “ML” means medium/low and “HL” means High/Low. I would also assume “59mm” is long shaft and “49mm” is short shaft. I don’t know this for a fact as it’s just an assumption. I don’t know if Motions tech support can verify this or not...
        What Motion should do is list the correct gearbox in the spare parts for each tank.
        • Rubicon99
          • 3316
          You are correct: Long = 58/59, Short = 49
          HL = high low, ML= mid low
          • Sureshot
            • 235
            So it appears my Tiger I needs a middle/low short shaft gearbox set.
            Thanks again,
            Steve
            • Olddowl53
              • Jun 2020
              • 45
              You can txt Dave a Forgebear and he will tell you what you will need.
