For the love of God ...
  • dai phan
    • Sep 2020
    • 726
    Greetings...
    Manufacturers... Could you please make your IR system a little less "prominently displayed " please? Apple, mushroom, hot dog, hamburger... I hate my detailed tank running around with a bottle of medicine on top of a turret. A casual observer asked what the heck is that thing on top of my tank ??? Nothing to do on this Saturday night so pardon my rant ... Dai
  • Rubicon99
    • 3316
    Originally posted by dai phan
    Greetings...
    LegoDEI makes an excellent low profile IR receiver. You have to install it which takes some basic hobby skills, but as you can see it sits about as low as an open hatch would.
    • dai phan
      • Sep 2020
      • 726
      Can it be mounted inside? Dai
      • Vaseline
        • 290
        Ive seen it done, but it means your running IR receivers to each side of your tank yourself.
        • Rubicon99
          • 3316
          It can be done, BUT you have to ensure your tank can reliably register hits from all sides and at varying ranges. This is rather difficult unless you have solid overall hobby fabrication skill sets.
          Because of the difficulty and amount of fabrication work required few actually do hidden IR receivers and hit indication LEDs. Most settle for low profile ones because when a tank is 25-35ft from you they can hardly be seen.
          • dai phan
            • Sep 2020
            • 726
            Makes sense. I guess my static model blood is still in me ! Dai
            • dai phan
              • Sep 2020
              • 726
              I bought the Taigen JS2 BB version because I understand their IR is not compatible with HL system. Anyway to make the Taigen IR compatible with HL? The tank will be here tomorrow. Dai
              • Rubicon99
                • 3316
                There is a conversation board by Mako but it’s performance is most often “lack luster”. Better to just swap out the Taigen MFU for a HL 6.0/6.1 system, which is rather simple process.
                • dai phan
                  • Sep 2020
                  • 726
                  I contacted Imex about changing from BB to IR in the future on the JS2. I was advised that I need a whole new IR turret of 167 USD ! Dai
                  • Rubicon99
                    • 3316
                    Once you start building/modifying and repairing your tanks you will see how much BS that is.
                    • Beeg
                      • 1335
                      • Texas
                      Something to keep in mind is that companies have to be careful of what they say to clients. They cannot advise about “mods” if they are not 100% vetted and supported for liability reasons. They usually can only advise for “replacement” components. MotionRC is no different in regards the products it sells and supports. This is one of the reasons we have “forums” to gleen information from “community” users for either easy or useful “non-supported “ modifications that work.
                      • dai phan
                        • Sep 2020
                        • 726
                        Well I am not going to buy a new metal turret at 167 USD just to get the IR function. I cannot see why a person could not buy the IR components and place into the current turret? May be the components are not available separately and you have to buy a whole bundle? Dai
                        • Rubicon99
                          • 3316
                          First off why would you want to use their sub standard IR components when there are others of far higher quality, performance and at a similar cost.
                          To make your JS2 fully IR compatible with your HL tanks you would need to either add a Mako secondary IR conversion board (which more then often don’t work well) or convert the MFU to a HL 6.0/6.1, Tamiya, Clark or IBU. Then add the correct corresponding IR “apple” base/wiring and IR receiver. (Note: IR base to IR receiver to MFU wiring is similar BUT not the same for all the available systems)
                          Then there is the IR bulb type, not all are the same. Some are more powerful and thus can score hits at greater distances and in brighter lighting conditions. Then there is the correct placement of the bulb.
                          Now all this may start to sound complicated but it really isn’t.
                          All these topics have been covered a number of time on this forum. If you do a little searching around you will find them.
                          • dai phan
                            • Sep 2020
                            • 726
                            I will do exactly as you advise as the Taigen IR leaves lots to be desired. I will get the tank today and see how I like the sound, smoke system, driving before I change to HL 6.0. Dai
                              • 4861
                              SoCalBobS and others. BriggsCowan has been banned for posting spam on numerous occasions in differing topics here at the Squawk. Thank you for Flagging his posts. Best, Steve
