I would like to build on what Rubicon has said about Hooben.
he and I worked over a Fury Ez8 Sherman pretty good which I now have and use in IR battles. It now resides on top of a Tamiya chassis. The top half is well and accurately detailed but the bottom was weak without bearing wheels and with Phillips screw heads showing all over in the suspension. It ran in a few battles fine after some hard test driving until a small stick went up into the idler and snapped it right off. That would not happen to a henglong taigen or a Tamiya, The plastic the Fury was made from was weaker than that of henglong. There was no good way to fix it so I trashed the chassis and put it on a Tamiya,
Hooben has bad rap what is well deserved. Their elephant kit is very detailed and nice looking but has bad trannys and the gun system needs to be reworked. My friend that built one was only able to get it to work with aftermarket trannys from ETO Armor, and li think different sprockets too.
I have seen two T55 kits and have always been tempted to buy one as they are very Tamiya-esk and have nice trannys. Not turn key models for sure but quite nice and I have not heard anything bad about the current production model kit of it, which is available at a good price from DKLM.
The new stuff that is coming out we will have to wait and see but it seems Hooben has upgraded their chassis and wheels with bushings that can be popped out and replaced with bearings on some of their tanks like the ZTZ they produce based on reviews and photos recently posted on RCU.
We are all hoping that the Cromwell and Merkava have bushing wheels and decent chassis.
I have pre ordered the Merkava to be a guinea pig for everyone as I would like this tank, I can’t have all Shermans..... I will post a review when it comes in in June if that date holds true. I’m not too worried based in what I have seen so far but I also have the skills to go total mad scientist on it and solve whatever it needs but I know many just don’t have the tools or skills necessary to completely rebuild an RTR tank.
So if your interested but leery, be patient and I will tell all when it arrives.
Overall, Hoobens tanks have had very little continuity to date. What worked well in one tank was not carried over to another tank. The Elephant, the T55 and the Fury Sherman are all very different nearly totally different models based on totally different principals. The trannys in the Fury were very nice, I saved them but being a proprietary shaft size.... who knows what I’ll do with them. Hooben definitely sank the Titanic with their poor effort on the Fury, just sad because if they had followed what they did on the T55 it would have been a winner.
I have seen things I liked show up in photo releases of the new stuff coming and things I didn’t like. So we will just have to wait and see, but.... I highly suspect they have not made the same massive mistake they made with the Fury tank they made. These new ones seem on the surface to be in the right direction.
So just wait and see till this summer and I will post the review of the Merk when it shows up.
