Heng Long King Tiger Build with IR conversion
  • BcuriousR
    • 133
    • Colorado
    I plan to take some time with this build. So, I'll update as mods and details are added.
    We'll start with the plan: The goals is to build an IR battler for the FRAG RC Tank Club battlefield that can model a build on a budget for beginners. So, I bought this 6.0 King Tiger with steel gears, 360 rotation, and Airsoft with Recoil. While a stock 6.0 can be built to battle without recoil, I thought I'd see what could be done with a slight budget upgrade. Thus, this KT will have servo recoil on a 6.1s board, (I'll sell the 6.0 to make up some of the cost.)
    Step 1: speaker upgrade: This is a Visaton FRS-7-4 (4ohm 2.5") speaker in a 3D printed enclosure in place of the smoke unit. (I prefer sound over smoke). While the stock speaker is 8ohms, I've never had a problem using a 4ohm on a Heng Long motherboard.
  • BcuriousR
    • 133
    • Colorado
    Step 2: Servo Recoil.
    I gutted the airsoft unit, then cut off the useless lower half.
    With very little whittling, I was able to fit a 9g servo in the remaining husk.
    The servo has some minor wiggle. It could be glued in place. As these servos can fail, I chose to print a small bracket to help hold it together.
    The final assembly: Okay not final. I still need to thread the IR bulb and IR restrictor into the barrel.
    I then printed some spacers to fit the stock recoil arm on to the servo
ID:	303149Click image for larger version
    Let her rip!
    • TokyoRC
      • Mar 2021
      • 7
      Good stuff!
      I am about to remove the airsoft unit from my Heng Long T-90. I want to remove mine so there is room for a high capacity battery. These T-90’s, while looking cool with their low profile, have quite a cramped hull.
      What did you use to cut the bottom half off with?
      • BcuriousR
        • 133
        • Colorado
        Originally posted by TokyoRC
        Good stuff!
        Just a plain old hacksaw.
        • TokyoRC
          • Mar 2021
          • 7
          I was going to use my dremel, but a hacksaw sounds like a quick and easy way.
          Thanks!
          • UltraVargen
            Dutchie
            • 266
            • The Netherlands
            Great work!
            • BcuriousR
              • 133
              • Colorado
              IR Receiver base and wiring day. I printed a receiver base, then built a wiring harness.
              The parts:
              The completed receiver base and MFU wiring for receiver and lights (uses LegoDEI receiver)
ID:	304036Click image for larger version
ID:	304037Click image for larger version
              Installed in the cupola:
              • BcuriousR
                • 133
                • Colorado
                Lots of paint work. I tried oil paint filters and sponge chipping.
ID:	304999Click image for larger version
ID:	305000Click image for larger version
                • BcuriousR
                  • 133
                  • Colorado
                  The finished model.
                  Click image for larger version  Name:	IMG_5272.jpg Views:	0 Size:	222.0 KB ID:	305004
                  The Servo recoil in action.
                  • UltraVargen
                    Dutchie
                    • 266
                    • The Netherlands
                    Excellent work BcuriousR !
                    I'm currently looking at speaker options for my tiny Panzer III, but find conflicting information on what ohm the Heng Long sound drivers are. Some places I read 4 ohm, others I read 8 ohm. It seems that aftermarket speakers can be found in both. Also I read having the wrong ohm speaker can damage the sound driver in the long run.
                    On the other hand: The max watt of the speaker doesn't seem to matter?
                    So the question is: Does it any of this really matter in case of a Heng Long board?
                    By the way, I like your servo recoil, but is it possible to make the retraction a little longer? I'd think it'd look even more realistic on such a big gun. :)
