My HL Abrams build thread
  • Hellcat 7
    • Aug 2020
    • 115
    • T/S
    Gents,
    First time taking my M1 apart to prep for painting and when it came down to take the idler wheel off I can't pop the cap off. Tried to flick it off, pull it off with a Gerber tool with no luck. What would be the best method without causing further damage to cap? Thank you
    • Rubicon99
      • 3316
      Originally posted by Hellcat 7
      Gents,
      Small drop of oil. Let it seep in then try again.
      • Hellcat 7
        • Aug 2020
        • 115
        • T/S
        Thank you.....Something so simple and here I am trying to pull the cap off all night. lol
        • Hellcat 7
          • Aug 2020
          • 115
          • T/S
          Any tips on how to make sure the hub caps don't fall out during battle? ( Metal and plastic).
            • 5402
            I use a rubber cement that comes with some of foam planes I’ve bought. Also good for sheet metal screws into plastic and the sheet metal screws into metal like the idler arms. I use loctite on machine screws like for drive wheels and the tanks that have machine screws into metal idler arms.
            • Hellcat 7
              • Aug 2020
              • 115
              • T/S
              Thanks Mr. Evan D for the tip.
              • Hatchling88
                • May 2023
                • 7
                • London UK
                Gents,
                Does anyone have any advice regarding how to put the metal hub caps into the metal road wheels? They are a super tight fit! I’m worried about damaging my tank if i hit them with a hammer - i am unable to press-fit them.
                (Newbie to the hobby here! Bought an Abrams from ToucanHobby which wouldn’t start up. Ended up taking it apart! Happy to share the details if anyone is interested!)
                • tank_me
                  • Feb 2022
                  • 1197
                  If you have small C-clamp, you could use a small piece of wood between the clamp and the wheel to press fit them on.
                  • Zippersnapper
                    Insane Unknown
                    • Mar 2021
                    • 502
                    • SW Texas
                    I hit them with a hammer................using a short 1/2" dowel as a punch
