“Junk / Scrap” yard M4 Sherman build.
Done. 10 minute work. The tank now looks much better. I am tankful :-)SoCal RC Tank Club Facebook Group
Gathering 1-2x monthly/All Ages & Experience levels welcomeComment
Is this the same barrel that you bought from Toucan? I want to replace the barrel on my Sherman that Rich stated it had the German muzzle brake. This one has the right muzzle brake, correct? And I can cut it down to 6.5 inches. Thank you!
It is a “Firefly” barrel I bought from Toucan hobbies off EBay. Like the “Fury” (panther) barrel it is too long so I cut it down to the correct length. Which is approx 6.5” (provided by Rich Johnson) or approx double the length of the stock gun from mantle face “pass through” to where the brake attaches (the muzzle brake is not part of the 6.5” measurement).
Note: The barrel is aluminum and the brake is integral with the rest of the barrel so it has to be cut off and reattach once the barrel is shortened.
https://www.ebay.com/itm/32478130848...3ABFBMpoXMo6pfSoCal RC Tank Club Facebook Group
Yes that is the one I have. I shortened mine though as it is a bit to long as supplied.
https://www.ebay.com/itm/32478130848...3ABFBMpoXMo6pfComment
The barrel arrived. I just want to make sure I do it correctly. I should measure 6.5 inches from the red arrow and cut it. I should also cut off the muzzle brake at the green arrow and reattach it to where the 6.5 cut off is. Correct? Thank you!
If the red arrow is the point where the barrel meets/clears the mantle then yes. I would cut the muzzle brake off first as it is easier to do when attached to a longer section on the barrel.
6.5” is a close approximation for a Sherman Firefly(mine is not a true Sherman Firefly and I took liberty with how it looks). The actual Sherman Firefly barrel was roughly twice the length of the standard 75mm gun and just slightly longer then the later “EZ8” 76 mm gun. So if it ends up slightly shorter or slightly longer it will IMO still look more proportionally balanced and overall better looking then the length provided.
I was trying to be lazy and wanted to cut it off first. Now since you mentioned it, I will play around with it. I will install it into the mantle to see how it looks. Then make a mark of where it clears the mantle and go from there. I will also check on the 75mm gun and double its length for more confirmation. Many thanks!
Little update on this project. Although everything has been running reliably the tank has a noticeable “wobble” when driving at lower speeds on flat ground. The cause is largely due to the drive axles shaft being slightly bent.
So instead of ordering new shafts I went ahead a ordered entirely new gearboxes. The new boxes are HLs “premium” ones. I have never been a huge fan of them and prefer the “black” Taigen boxes more, but I couldn’t pass up the sale price on them.
Once installed, the tracks back on and everything “buttoned up” it was off to testing. The wobble still remains but it was greatly reduced. The tank now has better low speed/power torque then the standard “silver can” gearboxes had, an added plus of the “blue” motors that came with the new gearboxes.
The slight wobble that remains is associated with the sprocket to track fit and the slight misalignment of the Mato rear idlers that are randomly catching the track teeth. It’s now such a minor issues that I am not going to chase the “rabbit” trying to sort it out further.
Stock gearboxes:
Heng Long “premium” gearboxes:Comment
A sale on Premium gearboxes? If you don't mind, please let me know where! Thank you!Little update on this project. Although everything has been running reliably the tank has a noticeable “wobble” when driving at lower speeds on flat ground. The cause is largely due to the drive axles shaft being slightly bent.
Once installed, the tracks back on and everything “buttoned up” it was off to testing. The wobble still remains but it was greatly reduced. The tank now has better low speed/power torque then the standard “silver can” gearboxes had an added plus of the “blue” motors that came with the new gearboxes.
The slight wobble that remains is associated with the sprocket to track fit and the slight misalignment of the Mato rear idlers that are randomly catching the track teeth. It’s now such a minor issues that I am not going to chase the “rabbit” trying to sort it out further.SoCal RC Tank Club Facebook Group
