Tiger II, Konigstiger, King Tiger. By any name, this German heavy tank was the most fearsome tracked weapon during WW2!
Faithfully recreated in 1/16 scale, Torro continues to grow its reputation as a producer of high quality, high functioning RC tanks. This Pro Edition of the King Tiger features more than 70% metal part construction, a 360 degree rotating turret, a realistic torsion bar suspension, and a barrel recoil and muzzle flash effect that fires in sync with the IR (infrared) battle system.
This version is delivered as RTR (Ready to Run), meaning it is fully functional out of the box.
All Metal Track System All of Torro's "Pro-Edition" tanks feature full metal drive systems. Single track links are connected with steel pins, propelled by metal drive sprockets and riding over metal road wheels and idler. Confidently conquer terrain with these durable metal tracks! |
High Torque Motors Reliable metal geared gearboxes are driven by high torque motors. |
Heavy Metal Castings Hoist hooks, spare track links and even simulated "welds" are reproduced in cast metal! Unsurpassed quality and realism combine to make this tank truly versatile as both a battle-ready and stunning display model. |
IR Battle Ready Engage in friendly infrared ("IR") combat with other tanks using Torro's proprietary IR Battle System, both inflicting hits upon and receiving hits from opponents! Sounds and action signal each hit, until the 5th hit disables the tank. After 10 seconds, the disabled tank restarts and can rejoin the fight! |
Onboard Charging Torro's convenient onboard charging system eliminates the hassle of removing batteries after every driving session. Safely charge the onboard NiMH battery by plugging the included charger's plug into the tank's concealed charge port. |
Superb Scale Fidelity Molded details, metal cast parts, brass photo-etched parts, and functional elements such as opening hatches all elevate this RC model to the next level, making it a perfect display piece when it's not powering through the battlefield outside. |
360 Degree Turret Fully rotate the metal turret 360 degrees, and move the all-metal barrel up and down to train on your target. Torro's integrated drive electronics gives you complete proportional control to translate your precise inputs to all axe of movement. Drive, turn, traverse, train, and fire! |
Barrel Recoil and Muzzle Flash Effect The Pro-Edition of Torro tanks are distinguished by their synchronized barrel recoil and muzzle flash effect. When firing the main cannon, the barrel recoils at the same time that an LED inside the barrel flashes and a firing sound plays through the tank's internal speaker. Normally a costly aftermarket feature, this entire system is pre-installed in this Torro Pro-Edition King Tiger. |
Exhaust Effect Glycerin-based "exhaust effect" simulates engine exhaust emanating from the two rear mounted chimneys. |
Torsion Bar Suspension Unlike simpler models with basic spring suspension arms, this Torro tank features a torsion bar suspension system that functions like the real tank! Torsion bars impart positive downforce on the tracks at all degrees of rotation, resulting in significantly improved traction over uneven terrain. |
- 70%+ metal parts including turret, main barrel, tracks and drive system
- 360 degree turret rotation
- Barrel Recoil with Muzzle Flash effect
- Realistic Torsion Bar suspension system
- Metal lower hull, drive wheels, idler wheels, and road wheels
- Single pad metal tracks connected with steel pins
- Onboard charging system via charge socket
- Proportional acceleration, steering, turret traverse, and gun movement
- Realistic sound system and smoke effect generator
- Fires an invisible IR signal to be used as part of Torro's proprietary Infrared Battle System, which disables other tanks when hit five times during simulated combat. Up to 20 tanks at the same time can battle each other!
- Torro German King Tiger 1/16 Scale Heavy Tank - RTR
- 7.2V NiMH battery with Tamiya connector
- 7.2V NiMH battery charger
- 6-Channel 2.4GHz radio transmitter
- Infrared (IR) battle system receiver
- Painted cosmetic accessory parts
- Adhesive decal sheet
- Set of small parts and accessories
- Smoke effect oil (vegetable glycerin)
- Sturdy wooden crate for transportation and display
- Complete instruction manual in English and German
- Six (6) AA size batteries for the radio transmitter – we recommend Admiral NiMH AA Rechargeable Batteries (6 Pack)
AGE LEVEL: 14 and up
SKILL LEVEL: Beginner
BUILD TIME: 1 Hour
| Scale | 1:16 |
| Length | 66cm / 25.9in |
| Width | 23cm / 9.0in |
| Height | 20cm / 7.8in |
| Weight | 6500g / 229oz |
| Body Material | Metal/Plastic |
| Chassis Material | Metal |
| Track Material | Metal |
| Motors | Two 380 motors (28x37mm) |
| Bearings | Metal Bushings |
| Gearbox Gear Material | Steel |
| Adjustable Gear Ratio | Fixed |
| Differential Type | Gear |
| Suspension Type | Bogie |
| Sprocket | Metal |
| Road Wheels | Metal |
| Idler Wheel | Metal |
| Adjustable Idler | No |
| Turret Rotation | 360 Degrees |
| Lights | Yes |
| Sound | Yes |
| Exhaust Effect | Yes |
| IR Battle Ready | Yes |
| Airsoft BB Launch | No |
| Track Recoil | Yes |
| Cannon Barrel Recoil | Yes |
| Required Battery | 2S 7.4V 1800mAh (included) |
| Required Radio | 6 Channel (included) |
| Skill Level | Beginner |
| Build Time | 1 Hour |
| Recommended Environment | Indoor / Outdoor |
