HL Sherman 105 mods question
  • 761st
    • May 2022
    • 392
    Hello guys. I finally had some time to play with tanks. I spent two beers working on the 105.
    1- Dremeled out the center exhaust deflector slots. Also drilled a hole through the top exhaust nipple and plugged the lower port. Using mega - steam. Thank you SoCal. Much better smoke when wanted.
    2- Unplugged LED 3 and 4 for head and tail lights. I never liked having them on.
    Now for the questions and another beer. (Leinenkugel's Summer Shandy, because it's 93 outside)
    !- Has anyone closed off the bottom battery hatch and moved the battery into the hull?
    I have modded some hull magnets and access would be easier for a Taigen style battery mount.
    2 - Has anyone mounted the Taigen speaker in the Sherman?
    Not much space as is. If I move the battery into the hull I will remove the battery shell except for one side for battery placement. That should give me more space as the Taigen speaker is taller.
    3 - Any source for latex tubing or ideas for the smoker?
    I lost the black plastic elbow.
    4 - Any power on/off switch relocation ideas?
    I am thinking behind the exhaust deflector and out of sight.
    5 - Should I just finish the 6 pack, order taco's and watch FURY for the 10th time?
    It's Friday and I am single, so cast your vote.
    Thanks guys.
  • DavidN
    • May 2021
    • 3203
    • Los Angeles, CA
    Here is my M4 105. I cut the battery compartment and put the battery in from the top. I no longer need to flip the tank over to open it from the bottom. I also use magnets to easily open the upper hull. The on and off button can be pressed from the outside at the rear (red arrow). This was Bob's idea. I don't like the smoke feature so I took it out.
    • DavidN
      • May 2021
      • 3203
      • Los Angeles, CA
      Actually, it is no longer a M4/105. It is now a M4/75.
      • 761st
        • May 2022
        • 392
        EXCELLENT! Nice job! I really like the 75 mount. What barrel is that? .30 looks pretty dam cool!
        • RichJohnson
          • 1276
          Beer, Fury, Kelley’s Hero’s, battle of the Bulge, Tank. Stack em up.
          • 761st
            • May 2022
            • 392
            Hell's yessah! I have them all. Taco's on the way! Thank you sir!
            • DavidN
              • May 2021
              • 3203
              • Los Angeles, CA
              I had a built tank day with a friend. I saw the barrel in box of US parts. I asked him if he had any use for it. I would like to replace my 105 with it. He gave it to me. I don't know which company that made it. It was a little longer and I had to saw it to the right length.
