Flakpanzer IV Wirbelwind
  • SoCalBobS
    • 2716
    • Southern California
    It's alive!
    My intrepid printer buddy has manufactured the 3DP parts I need to convert a Heng Long Panzer IV to a Wirbelwind. Now it's up to me to see how much customizing I can accomplish. Rotation and elevation is straightforward. I'm planning (hoping) to insert LED bulbs in the barrels. I'd use the machine gun circuit to activate them. I may even use spare HL IR bulbs that I removed for stronger ones from other tanks. That way I could fire the mg circuit for 5 seconds which will cause the main IR to fire, but at a shorter range. Or nothing may work, and it'll be just a showpiece! We'll see.
  • edwardyn
    • Aug 2021
    • 6
    The turret of the tank does not look big
    • SoCalBobS
      • 2716
      Pretty large...
      • SoCalBobS
        • 2716
        Another step. Turret painted with base color, barrels installed. Barrels are brass rods, At some point I'd like to substitute tubes with LED's inside so the rods are just press-fitted.
        • SoCalBobS
          • 2716
          I posted a clip on Youtube showing my progress. Here's the link:
          • Rubicon99
            • 3311
            Bob that is one of the best RC tank video “lead ins” I have seen in a very long time.
            Are you bring the new tank to the “October War” battle on the 9th? It would be a real threat because you could use the heavy AA MG feature to knock out IDF Sherman’s.
            • SoCalBobS
              • 2716
              Ahh, man! Why you do me like that? I have hooked up IR equipment. So, asking your opinion: The IR bulb(s) will be mounted in between the top and bottom AA barrel(s). Notice the plural, more on that later. They'll be in brass tubes to reduce side scatter. Also, they'll be inside the turret, and the slits n front are quite narrow. I'll be using my HL bulbs that I removed for stronger ones I'd like to install two, one on each side. I'm thinking that the weaker bulbs and two in a circuit may reduce the range. This would simulate the smaller caliber rounds. Any thoughts? If necessary I could also only shoot the mg circuit so I would have to stay on target for a long time to register a hit.
              Oh, and thanks for the nice compliment. There'll be a "Director's Cut" once the project is complete.
              • Rubicon99
                • 3311
                Two bulbs are OK. Rich has two in his AA monster and there have been no issues. I would make the tubes a little longer maybe 10-15mm to narrow the beams a bit but the standard depth is not going to upset anyone. Firing off the 6.0/6.1 MG circuit will pulse a shot once every 1.5-2 second. I would limit the firing to no more then 5-8 second burst with a reasonable reload time in between. Also maybe add three to four “pre hits” before the battle so it will only take three hits or less to knock it out.
                New HL bulbs have a range of over 100 feet so even powered down they will be able to hit targets a fair distance away. Just food for thought.
                • KAdams
                  • Feb 2022
                  • 21
                  Looks great. Very nice build.
                  • DavidN
                    • May 2021
                    • 3189
                    • Los Angeles, CA
                    So cool Bob! I can't wait to see the 4 LED's flashing at a high rate simultaneously :-) Will you be able to find a couple of German figures to set them in there?
                    • SoCalBobS
                      • 2716
                      I’m a novice regarding LEDs, so it’s a goal I hope to realize. As far as figures, there are 3DP figures that might work. Someday!
                      • Zippersnapper
                        Insane Unknown
                        • Mar 2021
                        • 502
                        • SW Texas
                        Bob, this is amazing. Excellent work sir !
                        If looking for solutions to LED's, reach out to Evan Designs. The owner is super helpful, even if you dont buy from them. They have LED's for just about every RC & smal scale scenario, and can custom configure if needed.
                        • SoCalBobS
                          • 2716
                          Thank you! As it turned out, I had just found that website. It's good to know that folks have had positive experiences there.
                          • SoCalBobS
                            • 2716
                            Camo. My airbrush was a b*tch today.
                            • Zippersnapper
                              Insane Unknown
                              • Mar 2021
                              • 502
                              • SW Texas
                              I'll take your worst day, over my best day, any day....
                              • KAdams
                                • Feb 2022
                                • 21
                                Looks great. Love the camo - it’s almost exactly how I was envisioning it should look when I saw it in just dunkelgelb the other night.
                                • SoCalBobS
                                  • 2716
                                  Loaded a new clip for you on Youtube. Back on Post 5 I linked a progress video. I've since deleted it in favor of this finished version, showing the tank outdoors. Same intro, but the second half has been changed.
                                  • SoCalBobS
                                    • 2716
                                    I finally installed four LED's. They're connected to the machine gun circuit, so they flash simultaneously. The photo is taken under some house lighting outside at night. The LEDs are "pico", 1.3mm in size, with hair thin wire leads. Very faint in daylight. I'm happy I was able to do it at all! There's a little surprise hidden between the two left barrels; an IR emitter bulb!
