Soviet Union KV-2 Upgrade Edition 1/16 Scale Heavy Tank RTR from Heng Long - HLG3949-001
Soviet Union KV-2 Professional Edition 1/16 Scale Heavy Tank RTR from Heng Long - HLG3949-002
A heavy assault tank using a 152mm main cannon, the Soviet KV-2 was produced at the same time as the KV-1. Due to the size of its heavy turret and gun, the KV-2 was slower and had a much higher profile than the KV-1. Due to an increase in turret weight from the expanded dimensions and a heavier gun, the turret traverse mechanism could work only on level ground. In service between 1940-1945, the tank was named after the Soviet defense commissar and politician Klim Voroshilov who operated with the Red Army during World War II. The KV tanks were known for their heavy armor protection during the early stages of the war, especially during the first year of the German invasion of the Soviet Union. In certain situations, even a single KV-1 or KV-2 supported by infantry could halt German formations. The German Wehrmacht at that time rarely deployed its tanks against KVs, as their own armament was too poor to deal with the Russian weapon. The KV tanks were practically immune to the guns mounted on the early Panzer III and Panzer IV tanks fielded by the invading German forces.
This Upgrade version features steel gears and plastic tracks for an economical balance between durability and weight. Heng Long has produced RC tanks for over 20 years, and their products offer an ideal starting point for new customers wanting to explore the world of RC tanks. All of Motion RC’s Heng Long 1/16 scale tanks utilize the latest TK7.0 MFCB for outstanding control, performance, playability, and upgrade potential!
Features:
AGE LEVEL : 14 and up
SKILL LEVEL : Beginner
BUILD TIME : 1 Hour
Durable Tracks Confidently conquer terrain with lightweight yet durable tracks that are easy to service. Professional Versions feature metal tracks for the ultimate in performance and realism. |
Independent Suspension and Steel Geared Gearbox Reliable gearboxes featuring steel gears efficiently transfer power while independent suspension provide traction over rough surfaces. |
Airsoft BB Launch Safely fire 6mm plastic airsoft BBs at the included paper target at short ranges. *Take safety precautions and wear eye protection. |
IR Battle Ready Engage in friendly infrared ("IR") combat with other TK7-equipped tanks, both inflicting hits upon and receiving hits from opponents! Sounds and action signal each hit, until the 5th hit disables the tank. After 10 seconds, the disabled tank restarts and can rejoin the fight! |
Scale Details The perfect balance of scale detail and practical operation, each Heng Long tank arrives factory painted and includes Cosmetic Accessory Parts to further enhance the tank's realism. |
RTR The convenience of the "Ready to Run" (RTR) format allows new enthusiasts to join the world of RC Tanks with ease! |
- Latest Generation TK7.0 Multi-Function Control Board (MFCB)
- Proportional acceleration, steering, turret traverse, and gun elevation/depression
- Programmable radio settings for the amount of recoil, the sensitivity in turns, the overall sensitivity in acceleration, high speed and low-speed modes, etc.
- Smoke effect (On/Off)
- Headlights and Brake lights (On/Off)
- Volume (five settings including Off)
- Four different sound sets. Each contains a unique engine start, idle, accelerating, traverse, elevate, machine gun, cannon firing, and shutdown sound
- Track Recoil (Three settings from low, medium, and high) -This shudders the tank briefly rearward to simulate recoil when firing the main cannon
- Fires a 6mm plastic BB (10 meters with minimal accuracy and limited velocity, but should still be treated with caution and with adequate eye protection)
- Fires an invisible IR signal to be used as part of Heng Long's Infrared Battle System, which disables other tanks when hit five times during simulated combat. Up to 20 tanks at the same time can battle each other!
- Independent suspension on all road wheels
- Heng Long Soviet Union KV-2 Upgrade Edition 1/16 Scale Heavy Tank – RTR
- 2S 7.4v 1800mAh Li-ion battery with XT60 Connector
- 2S USB LiPo/Li-ion battery charger
- 10-Channel 2.4GHz radio transmitter
- Magnetic Infrared (IR) battle system receiver
- Painted cosmetic accessory parts
- Adhesive decal sheet
- 6mm plastic BBs (50 Pack)
- 2x spare track links
- Smoke oil
- Complete instruction manual
- Six (6) AA size batteries for the radio transmitter – we recommend Admiral NiMH AA Rechargeable Batteries (6 Pack)
BUILD TIME : 1 Hour
| Scale | 1:16 |
| Length | 54cm / 21in |
| Width | 21cm / 8.2in |
| Height | 20cm / 7.8in |
| Weight | 2390g / 85.3oz |
| Body Material | ABS Plastic |
| Chassis Material | ABS Plastic |
| Track Material | ABS Plastic |
| Motors | Two 380 motors (28x37mm) |
| Bearings | Metal Bushings |
| Gearbox Gear Material | Steel |
| Adjustable Gear Ratio | Fixed |
| Differential Type | Gear |
| Suspension Type | Idler Arm |
| Sprocket | Plastic |
| Road Wheels | Plastic |
| Idler Wheel | Plastic |
| Adjustable Idler | No |
| Turret Rotation | 320 Degrees |
| Lights | Yes |
| Sound | Yes |
| Exhaust Effect | Yes |
| IR Battle Ready | Yes |
| Airsoft BB Launch | Yes, 6mm |
| Track Recoil | Yes |
| Cannon Barrel Recoil | No |
| Required Battery | 2S 7.4V 1800mAh with XT60 connector (included) |
| Required Radio | 10 Channel 2.4GHz (included) |
| Skill Level | Beginner |
| Build Time | 30 Minutes |
| Recommended Environment | Indoor / Outdoor |
