Russian T-90 battery options
  • cmdrcody
    Just buy the 3500mah shorty packs from Motion RC. I use them in my T-90 all the time.
    They are out of stock. Otherwise, I would not be looking for other battery options
  • SoCalBobS
  • cmdrcody
    Originally posted by keilau
    I use home built battery packs for my tanks. Half of them are 2S 26650 and half are 2S2P 18650. The only commercial packs are 3x 2S 18650 that came with the tank purchases in the last 1.5 year.
    Click image for larger version Name:	IMG_5125.jpg Views:	0 Size:	116.9 KB ID:	363134
    The first one came with German Leopard 2A6 was encased in a plastic hard shell to simulate the NiMH pack. The later one with T34 and Sherman are in common wrap package. HL rate them all as 1800 mAh. But the way I use them, they are only 800 to 1100 mAh as measured by the B6 iMAX charger which allows them to run the tanks with heavy tracks at full top speed for about half an hour. Typical normal on-off operation run time is much longer.
    I charge the pack to no more than 8.2 volts and the HL MFU stops when voltage drop to about 6 volts. Over the years, I learn that I can recharge the Li-Ion pack to several hundred cycles by avoiding overcharge and overdischarge them.
    Using the same methodology, my home built packs are rated at 4800 and 5600 mAh. They can run the HL at full speed for 2 or 3 hours. The key to the long run time is to use premium Li-Ion cells such as the Panasonic or Sanyo NCR18650. I use EBL cells and get similar results. I have not use NiMH or NiCd pack for many years and cannot comment on their performance. I like the Li-Ion pack much better.
    Have you read all the previous posts before you made your post?
    The Russian T-90 & T-72 takes a battery half as long as all the other Heng Long RC tanks. That is why I would want to install a battery that has more mAh than the 1800mAh that comes with the tank. Especially if I want to install the all metal threads and wheels. Can only fit a 2S (two cell) battery.
    Click on this and go to 11 minutes into the video: https://www.youtube.com/watch?v=2_jTy1Yaj1A
    Then you will see what I'm talking about.
  • keilau
  • Rubicon99
    The last paragraph above in post # 2 is incorrect. For the simple reason if it was true manufactures would be quickly sued for false advertising especially in the US under the consumer protection laws. The fact is they are not, because the batteries do and can hold more then 3000 mah.
    That’s not saying the batteries might have only 3000 useable (at full rated voltage 7.2/8.4/.9.6 before volts start to drop off) of say the peak 4000 to 5000 they are advertised at holding. But the fact is they hold the 4000-5000.
  • cmdrcody
    The RDQ is a very interesting option if the claimed capacity can be verified. It should fit a standard Heng Long battery well fine and has no need for chassis modification. However, it is designed for transmitter use which requires very little current. Will this 5C battery have enough output to drive 2x 380 motors? The answer is probably not. They are high internal resistance battery for very low discharge rate. A high risk of fire.
    You can find some useful information on battery in this thread.
    The basic about Heng Long RC tank battery packs - Hobby Squawk RC Forum for Airplanes, Boats, Cars, Helicopters, Tanks, and Trucks
  • keilau
    Originally posted by cmdrcody
    What is the maximum dimension size for a battery to fit into the Russian T-90 tank battery compartment?
    Can you use both Li-ion and LiPo 2S 7.4V type batteries with the XT 60 connector for powering the tank?
    Specifically, would the RDQ Series 7.4V 2S 5000mAh 5C TX16S Compatible LiPo Battery - XT60 or the NHX RC 2S 7.6V 5200mAh 150C HV + Graphene Shorty LiPo Battery w/5mm Bullets / XT60 work well in this tank?
    https://www.racedayquads.com/product...o-battery-xt60
    https://nitrohobbies.com/nhx9003xt60/
    The NiMH pack is made up of 6 sub-C NiMH cells to make a 7.2 volt supply. The best sub-C NiMH cell can hold 3000 mAh charge. It is not electrically possible to make higher than 3000 mAh NiMH pack with 6 cells connected in series. Some seller overcharge their pack to make higher capacity claim which will shorten the pack life
  • cmdrcody
    started a topic Russian T-90 battery options
