Call SkyRC technical support. They are very good. If you cannot charge 2S Lithium Ion battery to higher than 7.2 volts, your charger is defective or the program messed up. Is your charger new enough to be returned?
The skyRC charger manuel is very good. All the questions you ask can be answered there. My off-brand B6 did not come with a manuel.
Conventional wisdom advises not to charge Lithium Ion battery over 4.2 volts per cell. I use only high end Li-Ion and find SkyRC's recommended 4.1 volts to be a prudent approach. I use EBL 18650 battery mostly because they are still reasonably priced (not cheap to be sure). I typically get more than 2800 mAh from them. The new 18650 pack using NCR18650GA cells from AliExpress seems to top off at 1800 mAh when charged to 4.1 volts per cell. If they do not fail prematurely, which I mean 500 charge cycles or more, they are very good deal considering the price. Most importantly, they can sustain a good constant current discharge for more than 2.5 hours.
