Trouble with Barrel elevation & 7.0
  • Florida Ranger
    First Sergeant
    • Jan 2023
    • 54
    • Venice Florida
    Hi, I am currently upgrading a heng long Tiger II to a 7.0 controller, and adding a recoil barrel and 360 deg turret. Have worked thru most of the upgrade and have everything working well… however.. I cant seem to get the Barrel Elevation servo to work.. the servo works fine when plugged into the traverse servo at CN3, and ive plugged two different ones into CN4 and get nothing.. maybe a bad controller? Advice needed. Thanks Men!
  • Operator7G
    • Jan 2022
    • 35
    Sounds like you did all of the proper troubleshooting and confirmed the servo works and that other known-good servos also do not work when plugged into the barrel elevation port on the controller. If you bought the controller from China, you should contact them ASAP before the whole country shuts down for CNY. Hopefully you can get a replacement shipped before that happens.
    • Zippersnapper
      Insane Unknown
      • Mar 2021
      • 502
      • SW Texas
      For a minute there I thought you somehow got a servo to work on a 7.0 board. Check the board (port CN4) with a multimeter- when the motors are driven, it should read somewhere in the neighborhood of 5.8v. Polarity doesnt matter in this case. If you get nothing, time to buy another MFU
      • SoCalBobS
        • 2716
        • Southern California
        We're talking motors, not servos, right? Different things. Your picture shows the traverse motor plugged into CN4, and CN3 empty. So the motor isn't working there? Just to eliminate variables, did you plug the elevation motor into CN3? Or have you replaced the elevation motor unit with a servo system?
        • Florida Ranger
          First Sergeant
          • Jan 2023
          • 54
          • Venice Florida
          Im stopping for dinner chow.. but will get into CN4 with my meter shortly.. will report results..
          • Florida Ranger
            First Sergeant
            • Jan 2023
            • 54
            • Venice Florida
            Ok tested 7.0 controller output v at CN3 & CN4 as per Zippersnapper’s guidance. Results were 5.8v on CN3 & Zero v on CN4 when pressing controls. So a bad 7.0 right outta the bag? Any others have similar issue?
            Thanks for the help and comments from all!
            • Zippersnapper
              Insane Unknown
              • Mar 2021
              • 502
              • SW Texas
              That sux. Thats the first I have heard. If you bought from Toucan, and recently, chances are good they will send you a brand new one at no cost. Worst case, they are cheap on eBay. The 7,0's have only 2 sound sets, so keep that in mind when getting a new one.
              • Zippersnapper
                Insane Unknown
                • Mar 2021
                • 502
                • SW Texas
                It would be a major upgrade, if you put in a 7.1 MFU.....its pretty much a given the 7.0's are for sh*t and most peope hate them. Food for thought.
                • SoCalBobS
                  • 2716
                  I actually use some 7.0's in tanks that don't need servo capability. Happy with them, only drawback is the limited sound selection, but that's the case with 7.1's also. Both allow eliminating the toylike "spin" feature, a definite plus. Hoping the CS26's are good, with seven sound options.
                  • Paulh
                    • Jul 2020
                    • 43
                    What is a CS26'?
                    • tank_me
                      • Feb 2022
                      • 1182
                      Originally posted by Paulh
                      What is a CS26'?
                      Found something interesting on FB. Toucan posted this as a new main board for r/c tanks. Zipper, is this the one you are working with? I was interested in the listing of sounds, number 7 specifically. 7 sound effects: Leopard2 A6, Tiger II, Tiger I, Abrams M1A2, Walker Bulldog, StugIII, Panzer VIII, Maus.​
                      • Florida Ranger
                        First Sergeant
                        • Jan 2023
                        • 54
                        • Venice Florida
                        New 7.0 installed..barrel elevation motor now working! 5.8v @ CN4!
                        Followed the trail to the problem! Interesting glitch!
                        Thanks to all for the guidance!
