I recently purchased a radiomaster tx16s transmitter. I did so because I want to experiment with a good quality programable radio. Particularly I want to try simulated gear changes and momentum with my two 1/16 tamiya centurions. I have only had the radio for a few days and so far things have gone well. I have gotten the sticks set up as I like them. Cannon, machine gun and the lights I added are all set up to work on switch throws. My first attempt at having two forward and two reverse gears with built in momentum has worked well and I have left the stick for controlling forward and reverse set without momentum effects so I can easily go between momentum and not-momentum.
One thing I have not been able to get working as yet: the arcane stick ninja routines that tamiya uses to simulate the tank crew turning off or on the tank’s engine. I think the problem lies in my not understanding exactly what tamiya is trying to have these moves do. It’s hard to emulate something and assign it to a switch when I dont understand just what I am trying to emulate. Has anyone programed the start engine and shut down engine stick ninja routines and assigned them to a switch? If so, what did you do?
