Clark Wiring
  • SoCalBobS
    • 2754
    • Southern California
    Clark Wiring
    I'm moving a TK-50 from one tank to another. I need new motor wires for the harness. I have plugs that fit the motor sockets, but they are pre-wired, and the wire is quite thin, 22ga I believe.
    > Is 22ga wire strong enough to handle 2S motor current?
    > What gauge wire does Clark use? What gauge have you used if you make your own?
    > Can anyone point me to a source for plugs with thicker wire, or tell me how they solved this issue? I don't want to strip the wires from the motors on the original tank.
    TIA.
    Edit: Found the printing (so faint) on the wires; 18 gauge. That and JST-XH female connectors ordered.
  • SoCalBobS
    • 2754
    Any source besides DAK RC for the Clark Volume Control? It's out of stock there. TIA.
    • tank_me
      • Feb 2022
      • 1197
      Taigen, but it seems they are out of stock also: https://www.taigentanks.com/collecti...card-cable-set
      • DavidN
        • May 2021
        • 3203
        • Los Angeles, CA
        MotioRC sells the whole cable set including the volume control unit for a very reasonable price....The volume unit in the Clark's system is the same as the one in the Torro/Taigen.
        Buy Torro 1/16 Scale Tank 2.4Ghz Cable Set online at Motion RC. Order online with fast delivery.
        • tank_me
          • Feb 2022
          • 1197
          That is a good deal.
          • SoCalBobS
            • 2754
            Fantastic! Thanks. I ordered a couple. The wiring package is a bonus!
            • RichJohnson
              • 1276
              I jumper the volume pins and just go full volume because I and out of knobs long ago.
              • SoCalBobS
                • 2754
                That's what I have now too. I just wanted to quiet it down on the bench, but not turn it off completely.
                • Chs51
                  • Jun 2020
                  • 14
                  Can anyone post the Clark TK50 wiring diagram please?
                  • SoCalBobS
                    • 2754
                    You can go to their website then screen capture what you need. The TK40 & 50 are esentially wired the same.
                    • tank_me
                      • Feb 2022
                      • 1197
                      There is an easier to read version that I like to use.
                      Notes on the 8-pin connector:
                      Turret rotation + and - pins are not labeled as it doesn't really matter which is which being a motor connection. It can be swapped freely to get the right motor directions.
                      The MG and front headlight LEDs share a + feed, but have their own - ground feed.
                      General Notes:
                      CN6 and CN7 are the primary motor feeds and the + and - can be on either pin depending how your motors are wired. They can be swapped freely to get the right motor directions.
                      Cannon flash LED is for a standard 3mm or 5mm LED flash and not the Taigen high intensity flash. High intensity goes into CN3.
                      Ground wire (black) for the servo connections is closest to the edge of the board.
                      I've never fused any of my Clark board power inputs, but you can if you like. I don't think many have.
                      Must program the board with the Sony remote to use the servo recoil and servo elevation or they will act really weird. That weirdness has burned out servos before.
                      Click image for larger version  Name:	tk40 Wiring.jpg Views:	0 Size:	148.1 KB ID:	376476​
