New to the forum and lots of questions
  • RonV
    • Jul 2023
    • 32
    I've had my tanks quite a while, but I'm quite a rookie. I purchased my tanks from Phil Pflueger in Vista around 2011-12. These both have 27 MHz radio and board, metal tracks, and gears. I can't remember what board they have in them; I think they're 18's. I've completely torn apart the Pershing and did some detailing, and paint. I haven't touched the Bulldog except paint the 50 cal, and commander.
    I want to upgrade the radio and board. Will a 7.1 setup work in these? I have no problem changing out connectors if that's necessary, and if the correct ones are available.
    Is there a new version coming out soon that I should wait for?
    ​Any information would be greatly appreciated
  • tank_me
    • Feb 2022
    • 1182
    Unless you are doing servo elevation, servo rotation, or servo recoil you can use the TK7.0 board. The TK7.1 adds the servo functions. Same radio is used for the 7.0 and 7.1, but a 7.x radio won't work with a 6.x or vise versa. You will more than likely have to rewire some stuff to get it to work right. The 7.x boards are the latest boards and I haven't heard of any coming soon, but HL usually just starts putting them in tanks without telling the public.
    • DavidN
      • May 2021
      • 3189
      • Los Angeles, CA
      The TK 7.1 and its Tx will cost you up to $100. A TK26 is only $75 for both the board and the cool looking Tx YK26.
      • RonV
        • Jul 2023
        • 32
        What do the servo control's do, give you a higher resolution of movement?
        • MrChef
          • Jan 2023
          • 501
          • New York, Not the city
          Welcome to the forum Ron!
          I see you are already getting great advice.
          Enjoy,
          Chef
          • Jarlath
            • Jul 2023
            • 62
            • Ontario, Canada
            With HL tanks from 2011 era, you would likely have the horizontal cam system elevation that is continuous.
            Newer HL tanks use a side elevation that is no longer a continuous rotation, but have up and down limits. Servo does the same (limits up and down movement)
