I did a basic upgrade to a friend's PZIII. He had an otherwise stock 6.0 HL PZ33 that was modded to accomodate a full size battery in the bottom compartment. It needed to become battle ready for the guys at the CanAm RC Tank club. He wasn't worried about sound effects being proper, nor having anything that looked "non-period" in looks/features.
Enter JCC's standard IR combat tank retrofit. There is nothing wrong with plastic gearboxes when used on an all plastic tank (aka, no metal driveline components/hull), if they have the clutch. This was an all plastic PZ3, so plastic gearboxes would remain.
JCC's conversion list:
- Magnetize lower/upper hull (Battery box removal/sealing)
- Resin/epoxy lower hull for stiffness/mounting surfaces
- Hull flex bracing as needed
- Through hull gearbox mounting (Screws be damned, M3 pan head bolts in the bottom, locknuts inside).
- Layout/mounting of MFU/RX/Speaker/Switches/Battery in lower hull (Routing planning/cleanup)
- Turret Modifications
- Servo Recoil
- IR Emitter mounting (mantlet, barrel, upper turret, permanent/removable)
- Tamiya profile apple mount
- Flash
