HL PZ-3 Upgrade...
  • Jarlath
    • Jul 2023
    • 62
    • Ontario, Canada
    HL PZ-3 Upgrade...
    I did a basic upgrade to a friend's PZIII. He had an otherwise stock 6.0 HL PZ33 that was modded to accomodate a full size battery in the bottom compartment. It needed to become battle ready for the guys at the CanAm RC Tank club. He wasn't worried about sound effects being proper, nor having anything that looked "non-period" in looks/features.
    Enter JCC's standard IR combat tank retrofit. There is nothing wrong with plastic gearboxes when used on an all plastic tank (aka, no metal driveline components/hull), if they have the clutch. This was an all plastic PZ3, so plastic gearboxes would remain.
    JCC's conversion list:
    • Magnetize lower/upper hull (Battery box removal/sealing)
    • Resin/epoxy lower hull for stiffness/mounting surfaces
    • Hull flex bracing as needed
    • Through hull gearbox mounting (Screws be damned, M3 pan head bolts in the bottom, locknuts inside).
    • Layout/mounting of MFU/RX/Speaker/Switches/Battery in lower hull (Routing planning/cleanup)
    • Turret Modifications
      • Servo Recoil
      • IR Emitter mounting (mantlet, barrel, upper turret, permanent/removable)
      • Tamiya profile apple mount
      • Flash
  • Jarlath
    • Jul 2023
    • 62
    • Ontario, Canada
    Click image for larger version  Name:	PZ3-J01.jpg Views:	0 Size:	82.0 KB ID:	382089
    Battery box removal/sealing and magnetizing hull.
    Click image for larger version  Name:	PZ3-J02.jpg Views:	0 Size:	66.5 KB ID:	382084
    Adding a resin base to the chassis floor.
    Click image for larger version  Name:	PZ3-J03.jpg Views:	0 Size:	47.8 KB ID:	382082
    The Clark TK-40S (Tiger I sound set) & FS-I6S TX to be installed/used for controls
    Click image for larger version  Name:	PZ3-J04.jpg Views:	0 Size:	70.7 KB ID:	382086
    Original gearboxes re-installed. If it had metal tracks, or massed much more, steel replacements would be in order.
    Click image for larger version  Name:	PZ3-J05.jpg Views:	0 Size:	81.1 KB ID:	382087
    Basic layout for TK40, RX, and factory speaker (TK40 only has a limited Wattage output, so factory speaker is OK)
    Click image for larger version  Name:	PZ3-J06.jpg Views:	0 Size:	60.2 KB ID:	382083
    Mounting of JCC compact recoil unit and a mantlet mounted emitter tube.
    Click image for larger version  Name:	PZ3-J07.jpg Views:	0 Size:	81.6 KB ID:	382094
    Testing of driveline and recoil unit operation. Correcting motor polarity, recoil direction, sound tests, etc...
    You can see the custom PZIII/IV IR Mounting that fits inside the cupola).
    Click image for larger version  Name:	PZ3-J08.jpg Views:	0 Size:	71.5 KB ID:	382090
    Cannon, mounted, IR Apple base mounted. Tested for connectivity & functionality
    Click image for larger version  Name:	PZ3-J09.jpg Views:	0 Size:	79.8 KB ID:	382088
    Reassembled.
    Click image for larger version  Name:	PZ3-J10.jpg Views:	0 Size:	72.1 KB ID:	382092
    Reassembled, showing the IR emitter tube.
    Click image for larger version  Name:	PZ3-J11.jpg Views:	0 Size:	71.6 KB ID:	382091
    Top view showing the Apple Base exposed for attaching an apple for combat.
    Click image for larger version  Name:	PZ3-J12.jpg Views:	0 Size:	58.1 KB ID:	382085
    Power switch is located externally under the back deck, for ease of operation.
    Click image for larger version  Name:	PZ3-J13.jpg Views:	0 Size:	230.8 KB ID:	382093
    The finished product, fully tested for IR Combat.
    Future upgrades are aftermarket idler adjusters. The Stock HL mounts will crack/flex at some point...
    • SoCalBobS
      • 2717
      • Southern California
      I like your detail of using M3 bolts to anchor the gearboxes. I haven't had the screws fail yet, but it's a quality idea.
      • Jarlath
        • Jul 2023
        • 62
        • Ontario, Canada
        Also one of the reasons I like to resin pour a solid floor in my tanks for mounting the gearboxes. Prevents the trio of original little posts from taking all the assembly tension of the bolts on a gearbox side. Alternative is to use a piece of aluminum/brass tubing as a collar around the mounting posts to prevent collapsing.
        • tank_me
          • Feb 2022
          • 1182
          I felt the same way about the plastic mounts. They flopped around and were loose straight from the factory. I fitted the Mato metal idler adjusters to my HL PZ3 converted to an SU-76i. It was a bit of a pain in the rear end...literally. There was a lot of "adjusting" the metal parts to get them to line up with the HL track path and I even had to dremel off material from them because the tracks were actually striking the corner of the idler mounts. Wasn't a fun process, but the rest of your build looks solid. I also filled the bottom of the SU-76i with resin.
          • quitcherbitchen
            • 923
            • Altadena, CA
            What's the length of the IR brass tube? I have to upgrade mine.
            • Jarlath
              • Jul 2023
              • 62
              • Ontario, Canada
              I use 6mm OD x 5mm ID brass tube, 20mm in length. IR bulbs fit directly into the tube, usually leaving at least 10mm from tip of bulb to tube opening. A dab of Shoe-Goo secures the bulb and still allows replacement when needed.
