I am very happy with my all metal Merkava with red motors. Good trouble free tank.
Heng Long MERKAVA review, build out and field testing.
What brand do you have? Hooben or Heng Long? An all metal merkava is a hand crafted tank costing 3-4 times more than the HL plastic chassis Professional version Merkava. The Heng Long all metal Merkava is $1100 at Amazon. It is a different class of game.
https://www.amazon.com/TOUCAN-RC-HOBBY-HengLong-Military/dp/B0CL4VFCRJ?ref_=ast_sto_dp
HOOBEN 1/16 Merkava Israel RC Battle Tank Model No.6617 – Peach FrogComment
The chassis is not metal.
Henglong 1:16 7.0 3958-1 Merkava RC Tank Metal Tracks Wheels RTR Barrel Recoil | eBay
This is the HL metal track version, not the all metal version. Its listing reads:The chassis is not metal.
"Henglong 1:16 7.0 3958-1 Merkava RC Tank Metal Tracks Wheels RTR Barrel Recoil"
For an all metal tank, the listing reads:
"IDF Merkava MK IV FPV 3958 for Heng Long 1/16 RC Battle Tank Full Metal Chassis lnfrared Combating BB shooting"
I am not a fan of the Heng Long metal track. The HL metal track has single pin, open pin and hollow back side which runs and looks unrealistically. I have hybrid or metal tracks on all my other Heng Long tanks. The metal track are either Tamiya, Mato or Torro. More expensive but well worthy the extra cost.Comment
It is your RC tank. If you are happy with it, it is all it counts. Happy tanking!
However, I do believe that we should stick with manufacturer's version names to avoid confusion and potential fault.
You should go protest in LA. Even your "full metal" doesn't say it is. From your link.
HL-70-3958-HalfMetal-360-SS-FPV-BBSmoking-DZN1
Material: Metal, Plastic
Historically HL have had all plastic versions and then versions with various metal up grades. I got the one I linked.
Case closed. You call your tank whatever you want. For commercial transaction, I do believe that we should stick with manufacturer's version names to avoid confusion and potential fault.You should go protest in LA. Even your "full metal" doesn't say it is. From your link.
The LegoDEI and Tamiya sensors have 4 IR receiving ports on the inside. Each one is pointed horizontal to the ground (one at 0, 90, 180, and 270 degrees). Each LED has a shade over it which helps keep the sun from "blinding" the receivers. Each receiver can receive hits at approximately 120 degrees. Since that is more than 360 degrees, they overlap each other's receiving arc ensuring there are no blind spots.
The Heng Long and Torro/Taigen units have a single IR receiving port that point straight up in the air. Shooting IR signal to something pointed at a 90 degree away from you just doesn't work as well as when you are pointing the IR signal right at the unit on the same plane. Being that the IR receiver is pointed straight up, it tends to be "blinded" by the sun which inhibits the ability to register a hit.Comment
The stock HL IR receiver is intended for indoor use only but works well indoors. Why only indoors? HL thinking is it is not safe to fire BBs indoor do to ricochets. So their IR is a substitute for using BBs when indoors.
As stated in a prior post their IR receiver is easily blinded by sun light. Even over cast cloud sunlight blinds them. This causes it to not register hit's with any reliability beyond 5ft (1.5m).
Compared to a Lego DEI receiver which even in the brightest sunlight can register hits from 120ft (~40m) away when shot at by a stock HL IR bulb. Further if an aftermarket upgrade IR bulb is used.
For the cost the Lego DEI receiver is a steal as it turns a toy battle tank into something far closer to a professional hobby grade battle tank.Comment
