Heng Long MERKAVA review, build out and field testing.
    • 5385
    I am very happy with my all metal Merkava with red motors. Good trouble free tank.
    • keilau
      • Mar 2021
      • 1812
      • Windy City
      What brand do you have? Hooben or Heng Long? An all metal merkava is a hand crafted tank costing 3-4 times more than the HL plastic chassis Professional version Merkava. The Heng Long all metal Merkava is $1100 at Amazon. It is a different class of game.
      https://www.amazon.com/TOUCAN-RC-HOBBY-HengLong-Military/dp/B0CL4VFCRJ?ref_=ast_sto_dp
      HOOBEN 1/16 Merkava Israel RC Battle Tank Model No.6617 – Peach Frog
        • 5385
        HL so all metal is not chassis.
        • keilau
          • Mar 2021
          • 1812
          • Windy City
          I cannot understand your sentence. From all the reference I can find, the Heng Long all metal Merkava has a metal chassis and is very expensive.
          Can you provide a link for you Heng Long all metal Merkava?
            • 5385
            The chassis is not metal.
            Henglong 1:16 7.0 3958-1 Merkava RC Tank Metal Tracks Wheels RTR Barrel Recoil | eBay
            • keilau
              • Mar 2021
              • 1812
              • Windy City
              This is the HL metal track version, not the all metal version. Its listing reads:
              "Henglong 1:16 7.0 3958-1 Merkava RC Tank Metal Tracks Wheels RTR Barrel Recoil"
              For an all metal tank, the listing reads:
              "IDF Merkava MK IV FPV 3958 for Heng Long 1/16 RC Battle Tank Full Metal Chassis lnfrared Combating BB shooting"
              I am not a fan of the Heng Long metal track. The HL metal track has single pin, open pin and hollow back side which runs and looks unrealistically. I have hybrid or metal tracks on all my other Heng Long tanks. The metal track are either Tamiya, Mato or Torro. More expensive but well worthy the extra cost.
                • 5385
                Good for you. I am still calling it the all metal version and I’m very happy with the stock metal tracks that you are so against.
                • keilau
                  • Mar 2021
                  • 1812
                  • Windy City
                  Calling a Toyota Corolla a BMW does not make the Corolla a BMW.
                    • 5385
                    I told you all metal but not the chassis. I gave you a link. I have the freedom to call it all metal. The one with a metal chassis is not all metal either.
                    • keilau
                      • Mar 2021
                      • 1812
                      • Windy City
                      It is your RC tank. If you are happy with it, it is all it counts. Happy tanking!
                      However, I do believe that we should stick with manufacturer's version names to avoid confusion and potential fault.
                        • 5385
                        You should go protest in LA. Even your "full metal" doesn't say it is. From your link.
                        HL-70-3958-HalfMetal-360-SS-FPV-BBSmoking-DZN1
                        Material: Metal, Plastic
                        Historically HL have had all plastic versions and then versions with various metal up grades. I got the one I linked.​
                        • keilau
                          • Mar 2021
                          • 1812
                          • Windy City
                          Case closed. You call your tank whatever you want. For commercial transaction, I do believe that we should stick with manufacturer's version names to avoid confusion and potential fault.
                          • Woohoo\o/
                            • Feb 2020
                            • 186
                            • Cape coral Florida
                            How inferior is the included infrared sensor compared to the upgraded one sold on motion?
                            • tank_me
                              • Feb 2022
                              • 1178
                              The LegoDEI and Tamiya sensors have 4 IR receiving ports on the inside. Each one is pointed horizontal to the ground (one at 0, 90, 180, and 270 degrees). Each LED has a shade over it which helps keep the sun from "blinding" the receivers. Each receiver can receive hits at approximately 120 degrees. Since that is more than 360 degrees, they overlap each other's receiving arc ensuring there are no blind spots.
                              The Heng Long and Torro/Taigen units have a single IR receiving port that point straight up in the air. Shooting IR signal to something pointed at a 90 degree away from you just doesn't work as well as when you are pointing the IR signal right at the unit on the same plane. Being that the IR receiver is pointed straight up, it tends to be "blinded" by the sun which inhibits the ability to register a hit.
                              • Rubicon99
                                • 3309
                                The stock HL IR receiver is intended for indoor use only but works well indoors. Why only indoors? HL thinking is it is not safe to fire BBs indoor do to ricochets. So their IR is a substitute for using BBs when indoors.
                                As stated in a prior post their IR receiver is easily blinded by sun light. Even over cast cloud sunlight blinds them. This causes it to not register hit's with any reliability beyond 5ft (1.5m).
                                Compared to a Lego DEI receiver which even in the brightest sunlight can register hits from 120ft (~40m) away when shot at by a stock HL IR bulb. Further if an aftermarket upgrade IR bulb is used.
                                For the cost the Lego DEI receiver is a steal as it turns a toy battle tank into something far closer to a professional hobby grade battle tank.
                                • Woohoo\o/
                                  • Feb 2020
                                  • 186
                                  I really appreciate this info. I gotta get one. And so does my buddy
                                  • Woohoo\o/
                                    • Feb 2020
                                    • 186
                                    What’s this plug for? I searched the manual but no info. I may have missed it.
                                    • cmdrcody
                                      "Grumpy"
                                      • Dec 2022
                                      • 228
                                      • Largo, FL USA
                                      That plug is for an auxiliary machine gun for its flashing bulb. Check your instruction sheet to set it up.
                                      Click image for larger version  Name:	20240101_112424.jpg Views:	0 Size:	433.0 KB ID:	427612
                                      • Woohoo\o/
                                        • Feb 2020
                                        • 186
                                        Awesome thanks. I really don’t care for a flashing machine gun. Can I remove this? Will it have an adverse effect?
                                          • 5385
                                          The stock non flashing gun just covers it.
