Unofficial Coolbank M5A1 Stuart 1/16 Scale Light Tank Discussion Thread
  • SoCalBobS
    The M8 was an easy conversion to a Heng Long 7.1 battler. Install new or replace the connectors to fit. IR in the barrel, IR receiver on the MG tub.
    Click image for larger version  Name:	M8 Scott 04.jpg Views:	0 Size:	243.8 KB ID:	448744
    The M5 will be harder in one respect. The turret is more confined, and the IR emitter location will be problematical. I put the IR receiver on the left hatch. Picture later.
  • rb67mustang
    Originally posted by tank_me
    I will eventually tackle the M5 and the M8. They haven't languished on the shelf of shame long enough yet. I learned years ago that I need to buy stuff when it's on the market as sometimes kits go out of production and never return. Then the prices spike. It's the exact reason I have so many projects now and I've vowed this year to finish the oldest ones first.
    That's the best way to get things finished. None of us are getting younger. I look at things I haven't finished, and sometimes I honestly doubt they'll get finished. The main thing is to have fun and be creative in the process.
    Roger
  • tank_me
    Originally posted by rb67mustang
    It looks great, Tank Me, but after all the work I did to my 1/6 scale 21st Centaury M5 Stuart, I'm not going crazy with the 1/16 scale M5!!!
  • rb67mustang
    I replaced the center suspension philips head screw with an M3 x12mm bolt, but the one that came out was an M3 x 10mm. I didn't have a 10mm bolt on hand, but the 12mm fits fine.
    Others may have wondered this like me so I'll post my results. YES...the Classy Hobby upper will fit with very minimal fitting and it is better detailed. As shown I have done zero fitting and it fits pretty good. It seems the center section of the chassis on the Coolbank upper uses ball bearings for the turret rotation. It is removable and could be transplanted over to the Classy Hobby upper.
ID:	404936 Click image for larger version
ID:	404937 Click image for larger version
  • rb67mustang
    Here's the video from Mr Tank A Lots Youtube channel. He somewhat takes the Coolbank M5 apart. It's almost a 42 minute long video. At 23:46 minutes into the video, he takes it apart.
  • rb67mustang
    Has anyone started an Unofficial Cool Bank M8 GMC thread???
  • rb67mustang
    Originally posted by Max-U52
    I know a trick for making leather straps and rifle slings that you might find handy. Nowadays you can get duct tape in just about any color you want, so I picked up a roll of brown and cut a strip of it and then folded it over so the two sticky sides are stuck together. Then with a good sharp blade and a metal straight edge I cut strips about 1/16 of an inch wide. They make great straps and slings.
    Thanks for sharing; it's a great idea!!!
  • rb67mustang
    Another someone said that to open up the tank one had to remove the tracks. There will be four screws hidden there, plus the two visible under the rear deck. Haven't tested it, though! Here are some shots of the interior, filched from ColemanCollector on RCTW:
    SoCalBobS, Mr Tanks A Lot on Youtube has a video of opening up the Cool Banks Mr. He found the hidden screws, and he adjusted the elevation servo, and he also removed 1 track link because as we all know, the tracks are loose!!!
  • Sappo
    Okay,mass confusion with the Stuart, will not start after a bit of a break, got a fresh battery, the transmitter was flashing red and beeping, thought it was flat trans batteries, replaced those but it's still flashing red and beeping.Any ideas?
  • Sappo
    Well I finally got my M5, big thanks to a mate who didn't want it.Was doing some research and found a M5 in the Aussie armour museum that had a bit of a heart transplant, original engines were getting tired and because it's a regular runner they came up with a quick fix,twin 350ci small blocks, went from 200 odd hp to 660hp.Hot rod Stuart.So now when someone says my tanks too fast I can look em in the eye and tell em "nah mate, it's modelled after the Aussie armour tank
  • SoCalBobS
    Originally posted by boothill
    Sorry, I couldn't find where anyone talked about converting their tank to a M3 like the Haunted Tank of the comics or permanently increasing sound effects and changing speed. Also quieting down the gear noise. The conversion to M3 might not be exact but relatively close. I am most interested in conversion to M3
    I converted my M6 Scott (came chassis, a bunch of cosmetic differences, more turret space) to I/R battling with a Heng Long board. Space inside is EXTREMELY tight, much of it taken up with mechanics and electronics. An M3 would be fun, but it would take really a lot of work to make things fit and function. Compromises would have to be made.
  • boothill
  • Nochtune
    I just received my Stuart. I ordered the "weathered" version. It doesn't appear to have any type of weathering. Did they send me the wrong version? All the numbers on the boxes seem to be correct. Does the tank itself have version numbers anywhere on it? The weathered version costs a little more than the base version.
    Does anyone have any information on this issue?
    Thanks
  • Vintage Racer
    Anyone know if "SUPER SPIN" mode can be disabled? Manual as far as I can tell makes no mention of it, but you never know! Thanks in advanced.
    VR
  • Vintage Racer
    Originally posted by Dwayne
    Hello. I'm new to the forum and I recently saw the post about the Coolbank M5. It looked really nice, so I ordered one and received it this evening. I'm in the process of charging the batteries, so I haven't had a chance to try it out yet. The only thing that was missing from the sealed box was the manual for the transmitter. I've searched online with no luck in finding one. I was wondering if you all might have a pdf copy that you could send to me. I would really appreciate it.
    The manual is on the Motion RC Website, along with the transmitter manual as well.
    Buy Coolbank US M5A1 Stuart Green 1/16 Scale Tank - RTR online at Motion RC. Order online with fast delivery.
  • Davidsch
    Hello
    I may have missed something in previous posts, but you can slow the Stuart and Crusader down. It’s on page 4 (the high lighted section) using K button and the joysticks. What it doesn’t say is the switch F1 needs to be up in the fast mode.
    Also the turret speed can be adjusted the same way. If the neutral point/midpoint shifts you can correct it by following the previous highlighted section (C button plus joysticks). It took me a few attempts trying different levels but the result is a lot better.
    You will find you can slow the tanks down but still leave the steering motor at full power to maintain manoeuvrability on rougher ground.
    David​
  • RichJohnson
    There probably aren’t any pdf copies of it. I’m surprised you didn’t get a manual. I believe I tossed mine out with the radio I removed.
    you could try contacting coolbank on his Facebook page.
  • Dwayne
  • RichJohnson
ID:	427783 Click image for larger version
ID:	427784 Click image for larger version
ID:	427785 Click image for larger version
ID:	427786 Click image for larger version
ID:	427787 Click image for larger version
  • SoCalBobS
    Thanks, I knew I could count on you! Makes so much more sense to have that one screw than removing all those ball bearings. It's actually the Crusader I need to get into.
