Challenger 2 track adjustment
  • Steve Phillips
    • Aug 2024
    • 9
    • East Coast of NC
    I recently bought a henglong 1/16 challenger 2 tank my left track is very slack I don't have the manual and I can't find anything on the net about adjustment of CHALLENGER tracks any help would be greatly appreciated thanks Steve NC
  • Meter Rat
    • 504
    • Argyll and Bute, Scotland
    You will have to remove the upper hull. At the front of the tank, you should see the track adjuster.
    This need adjusting in or out as required. Excuse the rust. This was during heavy maintenance, and repair. Click image for larger version
    You may also need to remove a track link as well.
    • Steve Phillips
      • Aug 2024
      • 9
      • East Coast of NC
      Ok I see it I try that I was already thinking about removing track links if I couldn't find anything thanks for your help
      Steve NC USA
      • aceclarkatx
        • May 2025
        • 2
        How do you know if you have a bad track motor? I got a used 1/16 Abrams and it won't drive straight. The cheap controller doesn't have real trim switches. I adjusted the tension and no change.
        Thanks!
        • keilau
          • Mar 2021
          • 1815
          • Windy City
          Thanks!
          The Henglong controller has no trim adjustment. Your problem may be a pair of unmatched motors, a defective gearbox or misalignment of the gearbox. Many of the questions you have about Heng Long tank motors were discussed in this long thread where you can find some tip on trouble shooting.
          I have seen advice giveing in theese forums dont buy blue motors, should the question be what tank do you have? and whats right advice for that person, given that fact that you have a very recent tank that heng long dont suggests the red motors as a hop up they suggest blue motors in mine wich is the hop up i have done. Would
            • 5393
            G button and left stick left or right adjusts tank forward fine tuning.
            G button and right stick left or right adjusts tank reverse fine tuning.
            • keilau
              • Mar 2021
              • 1815
              • Windy City
              tk6page10.pdf
              Click PDF to download and open on your computer.
