Barrel on promotion version not firing BBs
If getting your own BB did not solve your problem, return the promotional version and get the upgrade version for $50 more instead. It is BB and IR enabled.Originally posted by EsDad View PostI’m disappointed in this Sturm III 7 promotion version not being able to fire BB’s - which is why it was brought. The box states it can but a sticker states not available on this model😔. Can I get a replacement BB enabled barrel? Any other options available?
https://www.motionrc.com/products/heng-long-german-stug-iii-f8-upgrade-edition-1-16-scale-antitank-vehicle-rtr-hlg3868-001?variant=41743214641337&utm_source=criteo&utm_m edium=display&utm_campaign=WebConversion-Dec27,2019&utm_id=204078&cto_pld=WyYR-6sGAQD9NtfkLR__Dg
I did. Don't expect much aside from novelty value. There won't be any ruby red glowing beam like on tv, just a red dot. The 6V lasers don't put out much light, invisible in sunlight. Also, they won't be giving you any accurate aim point, since the bb's shoot wild, and they drop after a few yards. That said, indoors it's fun to see the dot where you point the gun. I connected mine to the LED2 Aiming Light circuit so if I pressed the B button without the A button also, the light would come on. Would I do it again on any other tanks? ....maybe...
Your cat would like it!The more screws it takes to reassemble a tank, the more likely it is you left something out!
