Taigen King Tiger with early turret AKA PORSCHE Turret WTB
  • Vintage Racer
    Vintage Man, Vintage Car
    • May 2019
    • 186
    • Sucramento, Ka
    Been a minute, been working on this a little bit at a time and tonight I attached the first section of turret zimmerit. It's looking pretty good and it fits really nice after it's trimmed correctly. I do the final fit with around 200° f water and it just melts in like butter. It will contour around a lot of curves. Just have to take your time and don't get crazy impatient.
    I chose not to go with that number 12 vehicle from the Normandy campaign. If you look closely at the photos it doesn't have the base ring at the turret to contour in the early production turret with the hull, and eliminate the trap shot from the sides or front. It's just weird looking.
    Instead I'm going to model vehicle 114, which also fought in Normandy. It has the normal large main gun and just standard camouflage. I don't prefer to model any kind of strange or one-off vehicles which #12 what that tank was. I'm a really big fan of this Atak Zimmerit.
    • Vintage Racer
      • May 2019
      • 186
      • Sucramento, Ka
      You can find photos of number 114. I attached a couple, one of the actual vehicle and one of an artist concept.
      I work pretty hard at not making these camouflage jobs perfect. To try to feel how awful the guy doing the work had to feel. I've read that most of the time they didn't have the proper materials, reducer or hardener. They thinned the pigment with whatever they could find, so that had to be awful. They were painted in the worst conditions by people that probably weren't very happy to be there. I always think about how miserable they must have been while they were doing the work. Having done a lot of paint work myself on vehicles I can't imagine what it had to be like a paint outside in about any condition you can imagine. Day and night. Then you're done painting, they just throw a bunch of brush/vegetation on top of it. Then of course I might be wrong. They might have loved standing out in the cold at night painting. Just so the vehicle can get blown to hell... I've seen only one original paint German World War II vehicle in my life, it was at the Patton museum, a Stug 3. It looked terrible. Like it was unbelievably bad. Nothing like any picture you ever see or artist concept or box art. It was terrible. So I try to find a happy medium.
      Click image for larger version  Name:	king-tigers-belonging-to-the-503rd-heavy-tank-battalion-v0-3pyu23kkmwe81.jpg Views:	0 Size:	89.5 KB ID:	445442 Click image for larger version  Name:	pz-kpfw-vi-ausf-b-doroga-m4-sherman-schwere-panzer-abteilung.webp Views:	0 Size:	34.5 KB ID:	445443
      • Vintage Racer
        • May 2019
        • 186
        • Sucramento, Ka
        I don't know what motivated me, I went ahead and put the other side on tonight, you can clearly see here the preformed shape after heating with hot water, I soak the paper towel in the 200° water and lay it down on the Zimmerit while it's in position. It takes the shape of the item you're trying to make it conform to pretty quick. Make sure everything's dry, mix up your epoxy, you don't need much because you're putting it on thin. I don't mix it hot but I probably use more than I need initially and then scrape off what might be extra. I keep an isopropyl alcohol soaked towel nearby to clean off any extra epoxy that oozes out as I'm working out the air bubbles between the Zimmerit and the hull or in this case the turret. I keep a little space heater running on the workbench to warm it up so the epoxy sets quicker, you can use 15 if it's in a weird area and it might take a little extra to get it to conform but these were easy. 5 minutes was enough.
        Once the epoxy has set, just trim off the extra. There will be extra. The parts are designed to be a little larger than the area you're covering. I used number 25 blade medical scalpel which is one of my favorite tools. Dragging across the top and it just comes right off. Trim it down to the existing edge of the turret.
        Click image for larger version  Name:	IMG_20260309_201614027_HDR.jpg Views:	0 Size:	60.3 KB ID:	445445 Click image for larger version  Name:	IMG_20260309_203942300.jpg Views:	0 Size:	130.9 KB ID:	445446
        • quitcherbitchen
          • 923
          • Altadena, CA
          very nice work. Nice tip about the preheat.
          • Vintage Racer
            • May 2019
            • 186
            • Sucramento, Ka
            Thanks, the instruction included with the sets are very good, clear and concise. I didn't come up with it by any means. Its in the instruction. I was skeptical at first, but upon trying the technique, the resin parts give up immediately with the hot water. Only thing I would add is when you sand the parts out of the sheet, go slow and use just a bit of Dawn. Do the sanding wet. Add the Dawn to keep the paper from catching, and use one direction stroke, away from you. Otherwise it will bind and fold when it catches. It happened to me once, but not bad enough that the part was ruined.
            Atak has resumed shipping to the USA. I bought mine off eBay, from Australia. Crazy.
            • Vintage Racer
              • May 2019
              • 186
              • Sucramento, Ka
              Colorized this with GROK, kinda cool. The camo is far from how its modeled most of the time. I specified to use color film from 1944 when the AI did the conversion. If I remember correctly there are two Brit POWs in the shot. You can see them easily by the uniforms.
              Click image for larger version  Name:	KING TIGER 114.jpg Views:	0 Size:	373.2 KB ID:	445547
              • Meter Rat
                • 504
                • Argyll and Bute, Scotland
                Coming along nicely.
                • Vintage Racer
                  • May 2019
                  • 186
                  • Sucramento, Ka
                  Thanks very much, I sent a link to the owner of ATAK, letting him know I started this thread using his product, and he is pleased as well!
                  A bit of irony, which I found funny. I bought this one Saturday on eBay. It was $400.00 shipped, but what the HELL!
                  Now I have to order another set of Zimmerit, and shipping is a bit high of course, given the worlds current situation. You have to get the entire model to get the correct turret base ring. The Henschel hull does not have it, as that turret sat very close to the top of the deck.
                  • Vintage Racer
                    • May 2019
                    • 186
                    • Sucramento, Ka
                    Reference photo for field paint work, colorized with GROK.
                    • Vintage Racer
                      • May 2019
                      • 186
                      • Sucramento, Ka
                      Another angle...
                      • Vintage Racer
                        • May 2019
                        • 186
                        • Sucramento, Ka
                        Oh no, your model has overspray on the treads!
                        Click image for larger version  Name:	image (2).jpg Views:	0 Size:	107.1 KB ID:	446075
                        • 761st
                          • May 2022
                          • 392
                          Great work. Liking the detail. FYI - Nice 914. Click image for larger version
                          • Vintage Racer
                            • May 2019
                            • 186
                            • Sucramento, Ka
                            Thanks very much for the compliment. I love 914/6 types so much. I wanted to buy one when I was in high school, had one picked out, I was working at McDonald's. I asked my dad to co-sign for me and he would not because my great uncle was killed by the Germans in World War II in the 745TH Tank Battalion. He said he was not going to co-sign on some God damn German car. I bought my first one about a year before I retired from 20 years of service in the Air Force. I figured I'd earn the right to buy whatever kind of f****** car I wanted and I could afford it myself.
                            One of my first girlfriends had a 2002. Pretty damn good memories! Her's was Malaga Red in color.
                            I've raced with quite a few of those ranging from ones that weren't too fast to some that were very highly modified, very fast and well driven.
                            This is probably my favorite picture of my car, I was at an HMSA event, and when I saw the photo I realized I was carrying the right front tire into 8A. Never seen another car do that before. It's already been pointed out to me that my rear springs are probably too soft but if you go much harder on the rear of a 914 it's going to tear the body apart. Besides it makes for a great picture!
                            VR
                            Click image for larger version  Name:	20160726_171050.png Views:	0 Size:	516.8 KB ID:	446194
                            • Vintage Racer
                              • May 2019
                              • 186
                              • Sucramento, Ka
                              So the Taigen King Tiger showed up, my recent eBay accusition. It's in decent shape, and happy with it. Already ordered another ATAK zimmerit kit, but the chassis definitely has issues as it's all plastic with all metal suspension, road wheels, and tracks. I have my eyes on an all metal set up. Click image for larger version
                              • Meter Rat
                                • 504
                                VR
                                Love the picture of your car. I’m glad you have enlarged it, and given an explanation. I was trying to work out what it was from your avatar.
                                Probably slightly quicker than my pair.
                                Although the blue Acadiane is a street sleeper. Having had it original 602cc engine removed, and a 1200 BMW motorbike engine installed. It can give a good account for its self.
                                The new King Tiger looks awesome. Is that a Sopwith Camel I see in the background?
                                • Vintage Racer
                                  • May 2019
                                  • 186
                                  • Sucramento, Ka
                                  Its the new E-FLITE SE5A. Kind of fun to fly. I love WW1 Aviation history, my favorite ace was Albert Ball!
                                  I am so unfamiliar with cars in the UK. Never saw anything like that when I was there. Is it like a small pickup? Citroën? And a Renault? Is that right?
                                  The white 914/6 is 3 liter powered, and it does go quite well,, and it get awful fuel mileage!
                                  My Wife says it beautiful where you are.
                                  Got to run, headed to work! More soon!
                                  VR
                                  • Meter Rat
                                    • 504
                                    I had to look up the Porsche, as I don’t think we received them in the UK.
                                    761st very nice 2002.
                                    Both the blue van, and the white estate are Citroens.
                                    The SE5 I am familiar with.
                                    Anyway back to your build.
                                    • MrChef
                                      • Jan 2023
                                      • 501
                                      • New York, Not the city
                                      So the Taigen King Tiger showed up, my recent eBay accusition. It's in decent shape, and happy with it. Already ordered another ATAK zimmerit kit, but the chassis definitely has issues as it's all plastic with all metal suspension, road wheels, and tracks. I have my eyes on an all metal set up. Click image for larger version  Name:	IMG_20260326_195312680_HDR.jpg Views:	152 Size:	143.2 KB ID:	446440
                                      Ahhhhh my Unicorn! One-day she will be Mine... Been looking for awhile myself. Congrats on your acquisition.
                                      • Rob59
                                        • May 2026
                                        • 25
                                        • Netherlands, Europe.
                                        What a great thread!
                                        I happen to have 4 KöTi‘s with the Henschel Turm, and an early one is still missing in my collection too.
                                        They are rarely offered over here, and when I finally discover the ads, either they are already sold or way too expensive.
                                        Kind of funny what you guys wrote about your countries and so.
                                        Very recognizable, as I am from the Netherlands and a lot of people call it Holland.
                                        Holland however, are 2 provinces in the Netherlands:
                                        Noord-en Zuid -Holland. (North-and South-Holland)
                                        So I hate it too when people say I am from Holland!
                                        Did not want to blow this thread again, just wanted to share.
                                        Now back to the Tigers.
                                        Looking forward to see both of them in their final color.
                                        Will follow this with great interest!
                                        Great job so far,
                                        Rob.
                                        • keilau
                                          • Mar 2021
                                          • 1815
                                          • Windy City
                                          Rob.
                                          I visited Holland, no, Netherlands, many years ago. It is a beautiful country. But you cannot blame the foreigner for the confusion.
                                          Despite "the Netherlands" being the official name since the 19th century, "Holland" is still commonly used in sports due to history, simplicity, and familiarity. Historically, North and South Holland were powerhouses in Dutch sports, with famous teams and athletes hailing from these provinces. The term "Holland" is easier to chant and has been ingrained in sports culture, particularly in football with chants like "Hup Holland Hup."
                                          Internationally, "Holland" is more recognizable and quicker to say, making it a convenient shorthand in the sports world. For many, it symbolizes Dutch pride and sports heritage, keeping the name alive in stadiums and broadcasts worldwide.
                                          Moderator, sorry about this post being not RC related.
