Matilda III/IV by Tongde
  • SoCalBobS
    • 2754
    • Southern California
    It's out, mine arrived today.
    Only have done the two minute run test, all seems good so far.
ID:	443835 Click image for larger version
  • SoCalBobS
    • 2754
    I chose the metal version for the drive train - gearboxes, tracks, roadwheels - to be more robust. Tan version since I will be doing my own Caunter camo scheme.
    This is the pattern, apparently required in North Africa.
    The colors seen vary widely, the light blue seen often isn't seemingly accurate. The actual colors are;
    Silver Grey RAL 7001:
    Slate Grey RAL 7016:
    Over a base of British Light Stone RAL 61:
    Due to the limitations of computer colors, even these don't look precisely like the actual paint. Actually, not even close!
    • tank_me
      • Feb 2022
      • 1197
      I've been wanting to do the same scheme on my 3DP Matilda. Caunter info: https://www.keymilitary.com/article/hiding-plain-sight
      Click image for larger version  Name:	img_76-1_48.jpg Views:	0 Size:	76.1 KB ID:	443840
      • SoCalBobS
        • 2754
        Two quick observations: first, the turret traverse cable plug was loose and stopped moving. I opened it up (four screws) and re-seated it and it works. Second, and this is a characteristic of the subject model, not the r/c product; the tracks pick up debris and some of it ends up in the hull interior, more so than a tank with exposed return rollers. I suspected it would be the case because of the enclosing side skirts. It'll require more frequent after event cleaning.
        While it was open I replaced the unmarked generic battery with a 3500mah Admiral battery from MRC.
        • SoCalBobS
          • 2754
          Since I opened it, I took pics of the suspension. Complicated! Another reason to go metal. Imagine all those parts being plastic.
Name:	Matilda III TongDe 04.jpg
ID:	443865 Click image for larger version
Name:	Matilda III TongDe 03.jpg
          • Rubicon99
            • 3316
            Bob do the wheels have bearings or brass bushings?
            • SoCalBobS
              • 2754
              Can't say for sure at this point, but they don't freewheel like it has a bearing. They'd need 24 of them if so. There is a thrust bearing on the drive shaft to the sprocket. That's a new one.
              • SoCalBobS
                • 2754
                Okay, I'm tracking the turret motor issue some more. The turret began to not turn again, intermittently. I tried another TD board and the same symptom appeared. Someone on the RCTW forum was sharing something similar. I then tried a HL board and there was no failure (at least not yet).
                The turret gearbox is not the standard one found in other TD and HL tanks. It is exposed, see attachment. I believe this was done because of the very limited interior space. One hypothesis is the gearing stalls the motor, only sometimes, which is why two boards acted the same. Anyway, I'll be running the HL board to see if the behavior repeats.
                Click image for larger version  Name:	IMG_2802.jpg Views:	0 Size:	113.8 KB ID:	443882
                If others encounter this, let us all know. At some point I'll be contacting TD about it, and more detail always helps.
                • Rubicon99
                  • 3316
                  That gear set up is closer to what Tamiya uses.
                  Bob was your TD Tx in LP mode. In LP mode the TD unlike HL reduces the turret power by 30%. This could be why it was stalling.
                  • SoCalBobS
                    • 2754
                    Hmm, possible. The Tx was however it was set up in China, although the issue showed up on two boards. I'll play with it some more.
                    EDIT: You could be right. Although I'd pulled out the TD board, I was able to plug in the turret motor into it on the bench. The motor sounded stronger, and I didn't get it to stall. I'll have to run it longer to be sure. If so, Tongde should be told, unless it's been done before.
                    • PanzerLoco
                      • May 2024
                      • 104
                      by any chance,
                      do we know when the ''Queen of the desert'' will be available from MotionRC?
                      cheers PZ Loco
                      • MetaAlpha177
                        • Feb 2026
                        • 2
                        • France
                        Hello,
                        i have the same problem with the turret, i follow the post if someone find solution or if i can help :)
                        • SoCalBobS
                          • 2754
                          Originally posted by MetaAlpha177
                          Hello,
                          Per post #9, check if you are in low or high power mode. Button T & Right Stick up and down will toggle this. High power will work the motor satisfactorily.
                          • MetaAlpha177
                            • Feb 2026
                            • 2
                            • France
                            ok thank's i don't have see this message. I test it when i can
                            • SoCalBobS
                              • 2754
                              Paint progress. The basic scheme is in place. Touch ups, small parts, decaling, detailing and weathering still to do. No sky blue on this one!
Name:	Matilda III TongDe 11.jpg
ID:	444193 Click image for larger version
Name:	Matilda III TongDe 12.jpg
ID:	444191 Click image for larger version
Name:	Matilda III TongDe 15.jpg
ID:	444192 Click image for larger version
Name:	Crusader Mk III 13.jpg
                              • 761st
                                • May 2022
                                • 392
                                Really looks good!
                                • tank_me
                                  • Feb 2022
                                  • 1197
                                  It's amazing how a little paint can transform a model. Looks less toylike now that the factory paint is gone.
                                  • SoCalBobS
                                    • 2754
                                    Okay, different light, different angles. Decals on, and a driver fitted. They still need their faces painted.
Name:	Matilda III TongDe 17.jpg
ID:	444214 Click image for larger version
Name:	Matilda III TongDe 16.jpg
                                    So, something to share: The tank's interior is not walled off from the tracks when they return. This results in a ton of debris being dumped inside. So much so that DKLM RC is devising a set of partitions to stop this. DM'ing him about availability. This is his photo. I experienced the same.
Name:	grass invasion.jpg
                                    • SoCalBobS
                                      • 2754
                                      More progress;
Name:	Matilda III TongDe 20.jpg
ID:	444354 Click image for larger version
Name:	Matilda III TongDe 19.jpg
                                      • SoCalBobS
                                        • 2754
                                        Same tank, I just got it out to our battlefield.
