Baffled
  • #41
    What's the issue with the recoil? Is it servo recoil? According to the Clark TK50 manual, "RealRecoil Servo Port is always turned ON, no setting is needed to turn it​ on".
    • #42
      check to see if the servo went bad.
      • #43
        It's not a servo, I've been trying to find out how to install one to plug into the clark tk 50
        • #44
          Looks like you have the default Torro/Taigen recoil unit which is not servo driven
          Go down to the section that says "Example 3: Asiatam recoil unit installation:​"
          Then, make sure nothing is plugged into the servo ports except the programming jumper on the left+top most column
          Then you have to program the board to utilize Asiatam recoil mode which is POWER button, until you get 3 flashes indicating it is in Asiatam recoil (CN9) mode.
          Gathering 1-2x monthly/All Ages & Experience levels welcome
