Version Info: This vehicle is delivered as “RTR”, but requires the additional purchase of 4 (four) AAA alkaline batteries for the transmitter.
Every February, at Means Dry Lake in Johnson Valley, California, a feast awaits a group of brave racing enthusiasts—a combination of desert racing and rock crawling in an off-road race. The structure of the racing vehicles typically features an exposed roll cage that supports a full-time four-wheel-drive system, coupled with a long-travel suspension kit. These vehicles can reach speeds exceeding 200 kilometers per hour, with a high acceleration ratio that allows them to effortlessly dominate hardcore off-road vehicles in extreme rock crawling. Based on the FCX24 chassis, equipped with a roll cage body, the Lemur is exactly this kind of unstoppable racing vehicle.
FCX24 high-performance crawler chassis is made of high-strength nylon. Compared with traditional designs, the overall weight is lower and strength is increased. The mid-mounted transmission incorporates a low center of gravity and contains the 2-speed transmission, transfer case, and 130-brushed motor. Power is transmitted to the front and rear axles through universal drive shafts, mated with portal axles for optimum ground clearance.
The FCX24 is equipped with a straight, but an optional planetary gear differential can also be used and enhance with high-viscosity silicone oil to simulate the driving effect of a limited-slip differential. After installation, ultimate climbing ability will be reduced, but a reduced turning radius and a more stable high-speed driving quality can be experienced
Combine the versatile, go-anywhere fun of the FMS Lemur 1/24 Scale 4WD Crawler RTR with Motion RC’s industry-leading customer service and product support for an unbeatable package!
Longer Run Times The conveniently located battery compartment houses an included 1050mAh LiPo for extended run times and easy access. |
Precision Drivetrain The Lemur chassis features efficient and durable metal driveshafts for the ultimate in strength for crawling, rock racing, or bashing. |
Four-Link Suspension Utilizing a traditional 4-link chassis design, the Lemur includes long-throw dampers for maximum articulation and travel. |
LED Light Bar Light up the course with the included hi-intensity LED light bar for rock racing or crawling in low-light conditions. |
- Completely RTR
- Shift on the fly 2-speed transmission
- Portal axles with metal gears
- High-torque steering servo with metal gears
- 4-Link suspension system
- LED Roof Lightbar
- Durable nylon roll cage
- High-strength integrated nylon chassis
- 7.4v 1050mAh Lipo for extended run times
- Convenient USB charger
- FMS Lemur Green 1/24 Scale 4WD Crawler - RTR
- G3 transmitter v2
- R3A receiver v2 (installed)
- R3A ESC (installed
- 130 brushed motor (installed)
- Steering servo (installed)
- Shift servo (installed)
- 7.4V 1,050mAh LiPo battery
- USB charger
- Hex wrench
- Instruction manual
- 4x AAA Alkaline batteries for transmitter - we recommend Admiral 750mAh 1.2V NiMH AAA Rechargeable Batteries (4 Pack)
AGE LEVEL : 14 and up
SKILL LEVEL : Beginner
BUILD TIME : Less Than 15 Minutes
| Model Scale | 1/24 |
| Length | 209mm / 8.2in |
| Width | 128mm / 5.0in |
| Height | 120mm / 4.7in |
| Weight (No Battery) | 442g / 15.8oz |
| Wheelbase | 139mm / 5.4in |
| Ground Clearance | 38mm / 1.5in |
| Body | Injection molded roll-cage with polycarbonate panels |
| Chassis | Composite nylon scale-type |
| Drivetrain | 4WD |
| Wheel Size (Diameter x Width) | N/A x 19.5mm |
| Wheel Hex Size | N/A |
| Tire Tread | All-terrain |
| Bushing Material | N/A |
| Suspension | Four-link with dampers |
| Shock Type | Coil-over dampers |
| Transmission | 4WD shaft-driven |
| Gear Pitch | N/A |
| Internal Gear Ratio | N/A |
| Final Drive Ratio | 99:1 (low), 24.75:1 (high) |
| Pinion | N/A |
| Spur Gear | N/A |
| Differential | No |
| Ball Bearings | Yes |
| Brakes | Electronic |
| Electronic Speed Control | 2-in-1 RX/ESC |
| Motor | 130-size brushed |
| Battery | 7.4v 1,050 mAh LiPo |
| Max Battery Dimensions (L x W x H) | N/A |
| Servos | 2 |
| Radio | 3-channel |
| Lights | Yes |
| Sound | No |
| Water Resistant | Yes |
| Skill Level | Beginner |
| Assembly Time | Less than 15 minutes |
