New to the forum with a UH1-D 800 series
  • sfcfury
    • Mar 2019
    • 490
    • Baton Rouge, La
    Originally posted by Astronome
    Hello F106DeltaDart
    That's exactly what I did.
    Balanced blades
    Verified Center of Gravity: Vibrations still present blades removed.
    Head removed: ditto
    Well at this point, if you still that much vibration with the head off... either one of the torque drive shafts is caddy wompus, or just the main shaft is bent?
    • Astronome
      • Apr 2022
      • 56
      • France, Senlis
      Yes sfcfury, that's what I think too, but 5/100th of a millimeter is perhaps normal for machining the rotor shaft.
      Don't forget to pick me up if my English is too bad :pensive:
      Daniel
      • DCORSAIR
        • 1918
        • Selma, Ca.
        Daniel
        Did you try it with head on but no tail shafts or tail blades or anything else hooked up??? Can you get us a video of the vibration??
        • Astronome
          • Apr 2022
          • 56
          • France, Senlis
          Hello DC,
          No, but I found where the great vibrations came from.
          A big difference of pitch between the 2 blades because a problem of one my 2 Digital Pitch Gauge.
          3 degree of difference :thumbsdown:
          • DCORSAIR
            • 1918
            • Selma, Ca.
            Hello DC,
            Yep, that's the problem, don't forget this and I think a few people don't know this, you need to use a flat edged pitch gauge for the stock flat botton Roban blades, you get a true reading when the gauge is flat against the blade.
            • Astronome
              • Apr 2022
              • 56
              • France, Senlis
              Yes DC,
              but we must not forget that even after more than 30 years of model making we still make beginner mistakes.
              I really suck. Click image for larger version
              • DCORSAIR
                • 1918
                • Selma, Ca.
                Yes DC,
                Yes sir, you got that one right, sometimes I'm like, why did I not check this or that first, we all do it......​​​​​​
                • Astronome
                  • Apr 2022
                  • 56
                  • France, Senlis
                  Yes I agree
                  • sfcfury
                    • Mar 2019
                    • 490
                    • Baton Rouge, La
                    It definitely happens to us all! So getting the blade pitch corrected- did that solve the issue?
                    • Astronome
                      • Apr 2022
                      • 56
                      • France, Senlis
                      Yes sfcfury
                      • PawPaw
                        • Jan 2019
                        • 539
                        • Baytown, Tx
                        Hello F106DeltaDart
                        Balanced blades
                        Head removed: ditto
                        I’m confused. How did blade angle fix vibrations that were present when the blades were removed and when the head was off?
                        • Astronome
                          • Apr 2022
                          • 56
                          • France, Senlis
                          Hello PawPAw,
                          Without the blades there were still some vibrations, but I think it was normal.
                          I tightened the belt, there is now less vibration
                          • Astronome
                            • Apr 2022
                            • 56
                            • France, Senlis
                            Hi,
                            After the tests of the mechanics alone, I installed this one in the fuselage.
                            8.4 kg on the scale, without model accessories.
                            • DCORSAIR
                              • 1918
                              • Selma, Ca.
                              Hi,
                              Looks awesome and yes you will be up over 20lbs when your done with it, I was worried about the weight on all the ones I have owned, not an issue when your flying them, makes it very scale........
                              • Astronome
                                • Apr 2022
                                • 56
                                • France, Senlis
                                It's true DC, my old UH-1D weighed 23kg (50lbs) and the flight is totally different.
                                • sfcfury
                                  • Mar 2019
                                  • 490
                                  • Baton Rouge, La
                                  Looking good!
                                  • sfcfury
                                    • Mar 2019
                                    • 490
                                    • Baton Rouge, La
                                    What are you using for the tail servo horn?
                                    • Astronome
                                      • Apr 2022
                                      • 56
                                      • France, Senlis
                                      Hi sfcfury,
                                      I using a SAVOX DIGITAL SC-1258TG 12kg-0.08s for the tail
                                      and 3 SAVOX DIGITAL SA-1256TG 20Kg.cm/6v for the head.
                                      • sfcfury
                                        • Mar 2019
                                        • 490
                                        • Baton Rouge, La
                                        Well the actual servo horn is what I meant- it looks like you flipped the tail over?
                                        • Astronome
                                          • Apr 2022
                                          • 56
                                          • France, Senlis
                                          Yes I installed the tail rotor on the left side (like the real helicopter).
                                          With part VARIO 97/20
                                          Click image for larger version  Name:	8TlNMm (1).jpg Views:	0 Size:	76.6 KB ID:	346594
                                          There is also the spare part ROBAN:
