Installation of accessories: antennas, air intake, cable cutters, hinges, etc...
2nd coat of paint.
We can see on the rocket launcher pods the difference in color: On the left the RAL 6003, on the right the green Roban...:confused:
Looks great!
You are pretty much doing the same thing I'm doing! I am making all the same changes... I like that fan mount! Do you mind sharing the 3D file?
I'm not going to mount the rocket pods... as I'm going with a 'slick' version...
The painting is almost finished, (except the windshield which is very ugly and that I will redo) before the last finishes I mounted the mechanics to make a test flight.
Some photos of the Huey progress.
Painting of the rotor head in grey.
Painting the tail blades.
Installation of some decals, but their quality is so bad that I will make redo others.
To be continued.....
That baby is looking great, also the Roban decals are junk as you said, anyone know a trick to applying the stock Roban decals??, maybe we are doing something wrong, every time I have tried, they just fall apart on me.
It's not the installation of the decals that is the problem (I let them soak in a bowl of warm water, then slide them in place.)
But the backing of the decals is "pink" and the white, for example, is therefore pink when dry.
Another thing: on a mat paint the support is shiny.
I have to find the German specialist who had made me "tailor-made" decals (I don't know if my translation is correct) for my Cobra.
Yesterday, I remanufactured a 0.5mm thick PETG windshield, i used Roban's as a template.
It took me 2 tries to get there.
News from my UH-1D.....
I finished the replacement of the windshield with the installation of the wipers, the side protections with brass wire and various small things.
I made the pitot tube.
I also 3D printed the landing gear fittings
I received the pilot and copilot from WarbirdPilots , but they are "a little" large...
Preparation for the first flight early this morning before the heat.
nothing to say: no vibrations, very quiet.
more than 7 minutes of autonomy.
Unfortunately I was alone at the club, so no video.
I return a little more in detail on the controller and the JetiBox:
It's the easiest controller I've had to program, number of motor poles, rotor speed, reduction ratio, brake, etc.... and live measurements.
A very practical thing is to have access to the last recorded flight parameters (the photos show a test in the workshop without the blades).
- maximum current reached for propulsion (56A during my last flight)
- minimum battery voltage
- controller temperature
- max rotor rpm (1320 rpm during my last flight)
- max current delivered by the BEC (6A during my last flight)
- battery capacity used
- and various programmable alarms....
My only regret is not to report this info via Hott telemetry (and yes I'm in Graupner / JR) 😪
