The Official Hobby Squawk Code of Conduct
This is a sticky topic.
There is no set rule against affiliate linking per se as long as it pertains to the particular post/subject matter.
In other words, if you wanted to link to a random plane or spare part or accessory we do not carry and is the subject of your post/thread, that is fine. However, having affiliate links as part of your global signature is not allowed.
Hope that clears the matter up for you.My YouTube RC videos:
Thank you sire crystal clearThere is no set rule against affiliate linking per se as long as it pertains to the particular post/subject matter.
Acknowledged
one last bit of uncertainty which i will extrpolate to all other spheres of influence before i make my executions,
lets say a 5000mah 55c 3s pack is being referenced
can i post if mrc has this itm out of stock assuming the discharge c rating is not exactly 1:1?
or should i not think about this approach and steer clear of it all together, i dont want to hurt your business intentionally
Yep, you bet. What we are trying to avoid are obvious attempts to advertise our direct competitors in a spammy, aggressive manner, i.e. "Don't forget to check out ABC Hobby for all your accessory needs!"My YouTube RC videos:
This is well understood will conduct my postings with accordance to these guidelines and avoid such examples
thank youComment
