Freewing 90mm F-16 - Thoughts anyone?
  • cybersarg
    Ret AF Helicopter Mechanic / 40+ year RC Pilot
    • 12
    Freewing 90mm F16 CG
    The manual is not very clear but is the balance point measured from the tip of the wing? I want to make sure before i fly that i have it correct. Upside down or not for balancing?
    • Porkster
      • 290
      • Suffolk, UK
      From the wing root, where the wing meets the fuselage and gear down. Balanced up side down, although as its a mid wing this is not critical.
      • DCORSAIR
        • 1918
        • Selma, Ca.
        It's real easy to balance, where the wing meets the fuselage at the very leading edge tip, just measure back from there, I have over 100 flights on mine and it has a large CG range, but here is the problem with that. If you go with the stock CG from the manual anywhere in that range you will find that the F-16 will rotate nicely, the problem with the CG back to far is, it likes to float and pitch up on landing, with the CG forward, it doesn't rotate as nicely, kind of jumps off the runway and it will drop the nose more in the turns but flies great nose heavy, not as pitchy and lands so much better, cut your power on final to low throttle and the nose will pitch up, hold a little up elevator at a nose high alpha and use your throttle to adjust your sink rate and she will glide right in to a nice flare. It will take you a few landings to get it right but once you get it you will love the F-16. Here is a picture where I fly mine, comes out about 110mm-112mm, just put your fingers over the wing spar hole where my pencil is pointing, I balance mine upright and gear down, fly it this way until you get used to landing it, if you fly it tail heavy as per the manual, you will find it hard to land. Your fingers will make a small indent in the foam, makes it so easy, set it on the ground reach under it and feel the holes and waalaaa, adjust your battery to your liking on each flight.
        • Alpha10
          J e t - J u n k i e
          • 377
          • Chicago
          IDK man, that looks like a REALLY nose heavy cg to me...
          You must have an extreme amount of up trim in your elevator position to fly that far forward.
          I ended up between 123-126mm... Much further aft.
          • DCORSAIR
            • 1918
            • Selma, Ca.
            Yeah it's nose heavy as I stated that in my post. Just a couple of clicks of up trim is needed from the neutral point and it lands so much better with nose weight, for me that is, my CG is not for everyone, if you like a neutral CG then do not try mine......:)
            • slingshot
              • Jan 2019
              • 9
              hi to all, i have a f16 falcon , and i would like to switch out the stock 90mm edf. need a little more punch. any ideas? i was thinking about putting a scorpion motor in it.
              • slingshot
                • Jan 2019
                • 9
                this is my f-16 I'm talking about.
                  • 5402
                  6s? Why Scorpion??
                  • slingshot
                    • Jan 2019
                    • 9
                    I've been doing some research on motors. scorpion was up on the top shelf with a few others. gotta start somewhere wright.
                    • slingshot
                      • Jan 2019
                      • 9
                      yeah, 1-6s5000mah.
                      • FLYRCJETS
                        • Feb 2019
                        • 9
                        7 flights on the TB version and I'm finding I like the 115 CG so far. Been pretty fun little bird! First landing was kinda fast as I was tail heavy a bit.
                        • DCORSAIR
                          • 1918
                          • Selma, Ca.
                          Great, glad your liking the F-16, great flyer too, been flying the F-16 for three yrs now, I find the sweet spot on CG around 118mm, I put the new FW 4068-1835kv in mine, it is better than my 4068-1680kv on flight times, performance wise just little more thrust.​​​​​​
                          • Alpha10
                            J e t - J u n k i e
                            • 377
                            • Chicago
                            I believe you mean nose heavy if it's landing hot... That forward of a cg would cause that.
                            • FLYRCJETS
                              • Feb 2019
                              • 9
                              No tail heavy. You must keep the speed up when so as it goes high alpha when tail heavy
                              AMA 1527
                              • FLYRCJETS
                                • Feb 2019
                                • 9
                                It's pretty nice, going to a 7 cell 70C TP lipo setup as I have access to tons of those lipos from UAV missions.
                                • cybersarg
                                  • 12
                                  I have a 90MM Freewing F16 for sale 4 flights Never crashed
                                  Wwing has rash from sharp turn after landing, spare tail.
                                  350 +100 for shipping. If interested PM me.
                                  • Scale Master
                                    X USAF Pilot, Commercial IFR Jet Rated
                                    • Apr 2019
                                    • 86
                                    Freewing F-16 performs best on 8S full throttle the whole time..... no bad characteristics … the jets geometry and this wings demand more airflow for be true performance!
                                    Some of my Vipers... :)
                                    • gooniac33
                                      The Original Gooniac
                                      • Jun 2016
                                      • 1047
                                      There are 6s set ups that work really well too. 8s does work well but is not the only way to do it.
                                      • Scale Master
                                        • Apr 2019
                                        • 86
                                        Here are some pics of TWO Freewing Turbine Conversion T-birds I'm building
                                        First set of pics show a 2.5" pipe
                                        2 Tanks (24oz + 11oz internal taxi/smoke tank)
                                        UAT = 2oz
                                        JP 55mm Wheels and brakes.
                                        All for a k-45 turbine (my calculation show the jet will easily have 5-6 min flight time at mostly full power (Total fuel on board = 39oz)
                                        • Scale Master
                                          • Apr 2019
                                          • 86
                                          Custom 300 gallon centerline tank fitted
