Official Freewing 64mm Lippisch P.15 Thread
    Ordered yesterday. 13 hours later .................... shipped.
    Pilot Ryan is pretty good, Alpha is alright to, but this is the DUDE!
  • Oxotnik
    How much of a build? It literally takes longer to take it out of the box!! :)
    You insert the CF tube. Then apply glue to the wing, insert the connector wire, and stick the wing on. Then glue the other wing, insert the wire, and stick it on. Then glue the rudder on.
    I just inserted the antenna (didn't glue that) and pooof ... done.. There are only 5 pieces including the antenna and fuselage. Super-easy.
    Actually it took me longer to get the wires into the channel through the fuselage, they were being a bit stubborn. That increased my build time (and blood pressure) by 83%., but I got over it.
    Yep. It definitely takes longer to program a new model into the radio than to assemble this model. Getting the elevon servo wires pushed through the wing is definitely the most tedious part. The wings and V Stab fit well into their respective slots and were perfectly aligned. My only struggle is that I want to run a stabilized Lemon receiver, since the plane is so small, but I'm having trouble finding a good flat, wide spot onto which to mount the RX. I may end up mounting it inverted to the bottom of the battery hatch.
  • themudduck
    Hee Hee Hee... only one? I don't mean to thread-jack, but the F104 looks super-cool with the stripes. (Just like the P15) Here's my model in the air....
    There was a Belgian F104 that was painted like TI's model. It was saved for a museum. I've always liked this scheme and I painted my F-104 this way.
    Click image for larger version  Name:	ntm78-7.jpg Views:	1 Size:	47.9 KB ID:	122757
    You know...I have a F-104:Confused: However I want to paint my J-10 like this first. It takes a while to hand paint the black stripes.
  • themudduck
  • themudduck
    Originally posted by Bearcat
    Not much of a build is it?
    Can't wait!!
  • Bearcat
    Can't wait!!
    Originally posted by goosekiller1
    TiredIronGRB Love The Tiger Stripes JG26 ( 'schneller machen ) ;)
    Thanks, I really like that look, I have a HSD J-10 I plan to do the same way.
  • goosekiller1
  • Oxotnik
    A stupid little 5-minute unboxing and assembly video.
  • Bearcat
    I pulled the trigger tonight! Will order the landing gear hopefully when they come back in stock.
    Mine will be here tomorrow, for those that have it can you answer a question for me?
    Are the two wing servos Y'ed together and then plugged into the elevator or aileron spot in the receiver? I know the transmitter will get set up as a delta wing.
    One plugs in the aileron and the other plugs into the elevator.
  • dkalwishky
  • Beeg
    Some more ideas...
  • Beeg
    Nice....JG26 at the Tiger meet!
    Got the P-15 today, took about 15 minutes to put it together including installing the Admiral 6ch receiver and setting up the radio, after the Foam-Tac cured a couple hours I took it out and flew it. I really like my F-8 and F-105 but the P-15 is a whole different story...it is crazy fast and stable but be careful doing rolls on high rate as it's hard to see when it gets out there. To help with orientation I repainted it in a fantasy livery and added some leftover decals, I did the underside in flat gray and just masked over the factory decals.
    Click image for larger version  Name:	20180312_215524062_iOS.jpg Views:	1 Size:	182.2 KB ID:	122643
    Click image for larger version  Name:	20180312_215959807_iOS.jpg Views:	1 Size:	158.6 KB ID:	122642
    Click image for larger version  Name:	20180312_215920482_iOS.jpg Views:	1 Size:	184.3 KB ID:	122644
    Click image for larger version  Name:	20180312_215839477_iOS.jpg Views:	1 Size:	181.4 KB ID:	122645
    Click image for larger version  Name:	20180312_220108700_iOS.jpg Views:	1 Size:	100.5 KB ID:	122639
    Click image for larger version  Name:	20180312_215743599_iOS.jpg Views:	1 Size:	121.2 KB ID:	122638
    Click image for larger version  Name:	20180312_223135123_iOS.jpg Views:	1 Size:	89.5 KB ID:	122637
    Click image for larger version  Name:	20180312_223845398_iOS.jpg Views:	1 Size:	120.4 KB ID:	122641
    A cup of coffee and an hour in the AM and she will be ready to fly, gyro and all!!
    It arrived today! Super fast shipping!! In great shape. No time available to build today..... :P
  • tclaridge
    This looks like a quick build. Can't wait.
