Official Freewing 64mm Lippisch P.15 Thread
  • Bearcat
    Mine was maidened today and I used a Turnigy 1300 45c battery, I threw this bird out and straight out it flew and man with the rates in the manual I chose the lower rates and to me it was still too high!
    Speed was very good and the roll rate was snappy with the wind but the slow flying was very stable!!!! FREEWING WHY DID YOU DO THIS SMALL SCALE!? The jet screams larger scale!!!! Anyways landing with the 1300 size battery with a breeze made for a very soft landing.. not even a grass stain!!!!!
  • BobinAZ
    I had a couple of initial flights with mine today. Winds were variable at around 12-15 knots. No problem at all for this little rocket. A firm toss and it's gone! It definitely requires some reflex like most/all wings as Ryan mentions, and the low rate for the elvevons is, as Ryan also mentioned, plenty. Mine is powered by an Admiral 3S1600 30C pack and still has a slightly better than 1:1 thrust ratio. Full power during flying must be watched carefully as this thing will flat-ass disappear in a heart beat!
    Bob
  • Ole-Timer
    Flew mine today in some gusty conditions and it did very well. Having flown this type before, I cut my throws way back and used around 10mm. The preset of 1.5mm up elevator was right on the money for the 2200 I used. Flights were 5 minutes mixed throttle and landed with 3.8 per cell. It does nose dip on the throw a bit, just give it a firm toss and don’t overcompensate when you hit the controls.
    Should have come with a plastic belly pan as mines already getting scuffed up.
    I watched the videos of Ryan throwing this plane and it doesn't look like he really hucks it that hard. There was a slight dip in the first toss but the second one was barely noticeable. Maybe Ryan is a "real" man's man and his throwing arm is built like Popeye. Like all my wings, I've got some reflex mixed in with the gear switch so will see how it goes once the snow melts a bit.
  • Flyingaceaircraft
    Flew mine today - three flights - using a 3S 2200 - landed around 5 minute mark on each flight - probably could have gone longer... felt fine with the weight of the 2200 - will try it with some 1800's as well. Overall - flies great - with expo and throws setup as recommended, it's a great flying plane for the price. Love it.. highly recommend it!
    Hangar day at TIA. George teaching me how to toss it "like I'm mad at it". :) I must not have been mad enough on my first launch :Scared: but the second worked out fine. What a rush! This little thing is a hoot to fly. Thanks for the lesson.
    Ahhhhhhh............the infamous TIA Flight Dance Choreography School ;)
    Next we'll see you two holding hands and skipping down the runway:Silly:LOL
  • themudduck
    Hey guys, I flew mine a couple of times this morning for the first time. I had a helper launch it for me and I told him to launch it strongly with an up angle. I did experience the same thing others have described during the launch... you definitely need a lot of "up" because it does have a tendency to dive for the ground. It just doesn't have the airspeed it needs to fly at first, and this is pretty typical for an EDF. A few seconds in, of course you pick up some speed quickly and its not hard to recover. First time I didn't have enough and I "Landed it"... hey I meant to do that! Then on the second launch I used a lot more "up" and it did dip some, but recovered and off I went.
    First flight was with a light 1500mah battery. Second flight was with a 2200. I have to say I really think the 2200 was a LOT better. It didn't feel heavy in the air, but the extra weight made it a bit more stable. I had a much longer flight which was nice, and it just seemed to fly better with the bigger battery. I was flying in a light breeze (5-8mph) and it was buffeted around some, but not bad. It balanced with the 2200 right in the middle of the Velcro strap. (The 1500 was all the way forward)
    I balanced it right at 58mm just like Bearcat showed a few posts back. That seemed to be just right.
    After I got the controls adjusted to my liking I didn't have any problem at all. (First flight the rates were set quite low). At full throttle the P15 rips it up pretty good but I don't think is that much faster than my Durafly ME163, I could be wrong. (I think that the ME163 is definitely more stable - that may be because the ME163 is heavier.) I am flying with about 80% set on the dual-rate function for aileron and elevator. It makes a cool wooosh sound. Very exciting little jet!
    I'll tell you one thing, I think its important not to fly the P15 too far away from home base! Its so small that it gets tiny in a big hurry. I found it much more comfortable when I kept it a little closer in.
  • GBLynden
    I wasn't able to fly it today (hopefully tomorrow), but I was able to get my unboxing done and posted for it. Boy it is a beauty!
  • Bearcat
    Mine came in today!!! Already have her built but I am thinking of using a 1300 3s 45c battery for the first flight. what size is everybody using?
    58mm comes to the point on the wing root that I marked for CG.
    Has to have a pilot!! Very cool!! I should have done the instrument panel, but the color printer had too much junk on top of it !!! LOL Good job...
  • themudduck
    So for fun... I decided to take Hardway's lead and painted the inside of the cockpit dark grey.
    But first I cut out the cockpit floor and installed a balsa bottom, just to make it a little deeper overall.
    I had this old crappy figure that seemed like the right size. I repainted his duds (left the yellow scarf).
    Then I printed out a tiny F104 cockpit instrument panel and glued that in.
    Ta daaaa!
    Click image for larger version  Name:	20180316_183942.jpg Views:	1 Size:	118.2 KB ID:	123392
    Click image for larger version  Name:	20180316_184023.jpg Views:	1 Size:	117.6 KB ID:	123393
    Click image for larger version  Name:	20180316_191645.jpg Views:	1 Size:	105.8 KB ID:	123394
    Click image for larger version  Name:	20180316_191700.jpg Views:	1 Size:	100.6 KB ID:	123395
    Click image for larger version  Name:	20180316_192209.jpg Views:	1 Size:	98.4 KB ID:	123396
    Finished the wiring of the A3-L gyro and the Spektrum 610 receiver. I had to plug the gyro capacitor into channel 5 on the receiver due to gyro clearances. Put the 610 receiver as far back in the fuselage as possible. Attached with Velcro to the fuse bottom. Ran the wiring up and behind a 1/16th inch plywood gyro mount, laminated to 3mm Depron foam. You have to mount the gyro to foam, not wood, or the 3M double-sided tape will fail to hold the gyro. (BAD). I made sure to have a bind plug extension as well as a rudder extension routed to the front of the fuselage since I can't reach the receiver.... For binding and for a possible nose wheel in the future.... Very fiddly, but it works great so far!! I have done the same setup in the F-105 and F-8, using a 1600 MAH Admiral battery. Hope the maiden goes well....
  • tclaridge
    CFIT rob, you had your elevons at 1mm up on the TE, but did you also use a throttle --> Elevator mix? If so, what did you use?
    TiredIronGB for your mix at 10%, did you also use a 1mm up elevator trim?
  • denoferth
    Looks like I should have done my homework a little more thoroughly before suggesting using a 12 blade fan in this little bird as it requires a battery too big and heavy to be practical for anything other than quick up and down, missile-like flights if it would fit at all. I'd much rather go the other way with longer wings to make it a more practical flatland soaring bird for less hectic flying. This scratch-built Me-163 a Spanish modeler-built is what I have in mind.
  • tclaridge
    Good stuff gents. Thanks for the pilot report and mix sharing!
    After several more flights today I took the throttle/elevator mix down to 10% and now it's about perfect...it also really helps on launch.
  • CFIT rob
    Maiden..for testing i set three rates on my flight mode. 50% aileron-75%Ele, 75% ail-85%Ele,100%ail-100%Ele. Mid rate was low throws recommended in manual. High rate was high throws recommended. No gyro (yet),CHL 1800 30c , 2 mm up Elevator,Cg per manual. Wind 5-10 mph. Mid rates. Tossed at about 45 degree angle,full throttle.....left my hand and immediately flattend out and started to decend , with pucker factor at 110% got to the stick and leveled her out. Down trim a couple clicks (ended up 1mm). What a fun little jet. Flew mostly on my mid-rates for first batt. Lands easily but very easy to overshoot. Ended up setting high rate Elevator for all three. High rate rolls are almost too fast to follow. This thing is a riot to fly. I love my 105 and F8 for the scale appeal but this thing is just flat a** fun to fly. Winds were variable in speed and direction for my flight. I was suprised how stabil it was. Will be adding a stabilizer for launch purposes soon.
  • tclaridge
    Ya, this cockpit is begging for some details. I just got mine!! The paint job is fabulous. Well built. Nicely packed easy assembly. They even covered the fin pocket with tape to be removed before gluing! Nice touch. Can't wait to fly this one. Then I will return to the cockpit.
    Thank you Marc!! I thought it looked the "part" for a war crazed Nazi pocket rocket jock!!! :)
