Freewing F-4 drag chute mod
  • Helmsman52
    • 247
    • Saint Paul, MN
ID:	271476​ ​ ​​​​Chutes are $175 plus $5 shipping and $15 for overseas. $25 for plunger assembly.
      Masterful work!
      • combatflyr
        • Jul 2020
        • 15
        Really looking for black and yellow
        • Helmsman52
          • 247
          • Saint Paul, MN
          This is the black and gold I make.
          • Turbine guy
            • Feb 2021
            • 2
            What is the inflated diameter?
            Can you make larger ones?
            • Helmsman52
              • 247
              • Saint Paul, MN
              The flat diameter is 17” for this certain scale model. The real F-4 chute has a flat diameter of16’. I make chutes according to scale up to 35” in flat diameter. Thanks.
              192 divided by your scale = ?
              192 divided 7 = 27.43”
              • Turbine guy
                • Feb 2021
                • 2
                I’d like to purchase a 24” one
                Please message me for payment info
                • paulsnapp
                  • 81
                  • Lebanon, TN
                  I have my chute mod done and ready to go as soon as I repaint the tail section to match. I have finally found a paint mixture to match the original and have sanded and painted twice. Color looks good but I am not happy with the finish around the fiberglass tail mod. The filler seems to stay porous and I can not get a smooth finish. I have tried Tamiya Basic Type Putty and Foam-Tac Foam Filler, sanded and followed with Foam Tac Foam Finish and Hobby Coat. I am using 1000 grit flexible sandpaper. When I sand, the filler does not sand smooth and hard but feels like maybe rubber and stays porous. Could someone please share what you use to fill and smooth gaps and rough areas before painting? Thanks!!
                  • SanExup
                    • 912
                    • Western Wy.
                    paulsnapp Lightweight spackle that can be found in hardware stores, for spackling walls. It spreads well and sands well, and is light in weight. I know I've seen some you tube videos where a specific brand is recommended. RcGeek probably has a video tutorial. I believe the stuff I have used is made by dap products. There might even be an ultra lightweight. The key word on the label should say sandable.
                      • 5401
                      What they call performance spackle. It's thicker and dries harder than normal spackle.
                      • paulsnapp
                        • 81
                        • Lebanon, TN
                        I have tried several things to try to get a smooth finish for the chute mod. I have tried green Tamiya putty, Beacon Foam-Finish and Beacon Hobby Coat, and this last round a very fine spackling compound. For each try I sanded with 2000 grit sandpaper before airbrushing on the paint. I have attached a couple of pics and you will see it is far from getting a smooth finish. Can you please share with me what your technique for doing this is? Thanks!
                        • paulsnapp
                          • 81
                          • Lebanon, TN
                          I have finally finished my chute mod along with installing a beefier elevator servo, plywood elevator servo mounting, 4-40 pushrod with Carbon Fiber sleeve and a heavy duty ball link. Now I need to finish my Phantom!
                          • Talal
                            • May 2022
                            Here is the red and white drag chute I’d been working on. Click image for larger version
ID:	129841Click image for larger version
ID:	129840Click image for larger version
ID:	129839Click image for larger version
ID:	129838Click image for larger version
ID:	129837Click image for larger version
ID:	129834Click image for larger version
                            How can I order it
                            • GliderGuy
                              • 1412
                              A precautionary note: I lost an F-4 due to what was likely an RF noise induced glitch.
                              Search this forum on RF chokes or chokes. Read the info presented and consider adding them.
                              I have not had any radio issues on HIGH CURRENT EDF planes since I began using them.
                              Your decision….but you may be at risk if you don’t install them.
                              • jasmith41
                                EDF-obsessed
                                • Sep 2021
                                • 317
                                • AZ and NE Ohio
                                I put those on every plane i have after the first Viper 90 incident. That wasn't the problem and lack of skill was / is, but it can't hurt. A guy i know even put them on servo wires in the Mig29...
