  • Airguardian
    Can we register Supermaneuverability as a religion already?
  • Airguardian
    Some more Sukhoi action :)
  • FlyingFighter
    Your batteries were probably not very good. I use 2S 610mAh on my jets and have no issues.
    That said, I typically only pull 2 flights out of each before replacing, 3 at most.
    What brand were you using?
    Their 'C' labeling was probably fiction and that's why you had problems.
    I used admiral pack from motion rc. Actually still using admiral ones for the bigger pack. I use one pack for two flight for safety, never goes under 50%
    Also I use a satellite rx with the admiral rx1000 dsmx receiver.
  • Airguardian
    Su-35 like you've never seen before!
  • Airguardian
  • FlyingFighter
    That's a pitty... what battery size (cells, capacity)were you using for the Rx pack, if I may ask?
    Hope your next jet is free from these problems! :)
    Currently I'm far away from my rc equipment and planes but if I remember well I used a 2s 600mah 30C at first. Motion support said to me that it could deliver only 18000 Amp max and it's not enough for such a big a model with all thoses servos operating at the same time. So they told me to increase the capacity and would not have such failure. Now I use a 1600mah 25C 2s, delivering 40000 Amp and did not have any brown out
  • Airguardian
  • FlyingFighter
    Originally posted by C17loadmaster
    I crashed a few by stalling on takeoff too. Same exact break points. A little balsa filler, clear coat, and paint will get it back to new.
    I now use larger packs and turned down the rates for takeoff. Problem solved
    Mine crashed because of wrong reception battery pack, it was too small to feed all the servos and it led to a rx brown out causing my plane to crash, motion rc helped me to find that problem and told me to use more capacity for rx battery, I now use a bigger 2s pack to feed the receiver using the 6s pack only for EDFs, following Airguardian advice. I lost my brand Arrows mig 29 cause of brown out on the third flight don't know why exactly as I used the recommanded battery spec and known receiver. I bought the sukhoi to replace that fulcrum and I was so afraid to loose her the same way, hoppefuly thanks to Guardian I'll be able to fly the majestic flanker for a long time!
    Here are some post crash picture. I also had the main gear cutted in half, I had to temporarily adapt my fulcrum ones waiting for original replacement.
  • Airguardian
    Slow-mo version of the previous video:
    Originally posted by FlyingFighter
    Hello to all! I bought one of those beauty some 3 months ago and I would like to thank you Airguardian, during the delivery time I watched a lot your video on how to improve that beast and tried to follow your advices the best I can. Didn't allowed me not to crash her twice at firsts try but she's still flying great now!
    Ouch... what happened? :o
  • C17loadmaster
    Hello to all! I bought one of those beauties 3 months ago...
    FF, great repaint, Sir. She is definitely a beauty. Best, LB
  • FlyingFighter
  • Airguardian
    Hands on transmitter 'split screen' footage :)
    These were FPV flights but forgot to turn on the DVR (except for the 3rd flight), silly me.
  • Airguardian
    Originally posted by SanExup
    A small daydream on my part: [...]
    Either way, your video/flying is very cool! It looks super fun.
    Thanks!
    I've heard about but have not seen quadcopter drones 'synched' up to fly patterns together. I have to imagine, an engineer will/can develop some sort of proximity lock on device that would enable formation flight. With an active lead and a temporarily passive wingman. And then disengage as needed. There must be a way to do this, maybe it's not possible or available in the market at the moment or cost prohibitive for hobbyists. It's something I've thought about a few times, so perhaps someday.
    Or... you can hone your skills and have another very skilled pilot-buddy get to chase you with a quad!
    What is the FPV system you are using? The Hud display looks great! Is it a Matek system?
    That's the Feiyutech FY-41AP but would probably not recommend it. Lots of issues with PC programing and ground station software not launching, amp gauge capped to 40 useless amps, not customizable looks, AHI is poor... but works fantastic for the rest as an OSD. Haven't tried much the stab functions yet.
  • SanExup
  • Airguardian
    I have three flight modes with different rates and expo on this jet, thought precisely to be able to make formation flight with more precission... that said, the flights shown here were conducted entirely on my typical acro setting with the highest rates.
    Extra expo and limited throws do help in formation flying, that much is obvious and I have practical experience with it.
    But most important of all is to make sure that both jets track as straight as possible, which is a combination of aircraft setup, weather conditions and pilot skill. ;)
    Gyro stabilization would help too... will get there eventually!
    Haven't yet properly tuned the settings of my FC to use stabilization the way it is meant to be used.
    (So I am flying unstabilized so far).
  • SanExup
    So cool Airguardian I am curious if its possible and if you think it would help to have a switch for more expo while flying in close proximity? That seems to be the hurdle of formation flight, getting close and staying close.
  • Airguardian
    This is the pinnacle of the hobby!
    (At least until I get into dogfighting, lol)
  • Airguardian
    Having fun as usual :)
  • paulrkytek
    Winter touch up and landing lights on my SU35. Lights are 5to 7v rated leds fed off my rx bec set at 5.5v, they consume about 5mah per flight and are simply wired so that when the rx is on the lights are on.
