Glad to see my video inspired you!
Did you also see my build video?
I have an entire piece on setting up the jet, fine tunning and reccomendations:
Regarding take-off from grass, I would rather leave TV on as you may need it to rotate depending on your grass.
Flaperons definitely help too.
Trick usually is to let speed build before pulling on elevator, otherwise they act as massive airbrakes adding to grass drag and the jet stays on the ground... or even worse, you end up producing a cobra take-off!
